[SOLVED] NRF24L01 with PIC16F73 Problem
hamid159
Full Member level 3
Full Member level 3
Lahore
Hy guyz,
I am making a wireless communication link between two same microcontrollers i.e, PIC16F73 through NRF24L01. I don't know why it is not running properly. What i am doing is, sending a character 'A' from one microcontroller to other through NRF24L01. and checking the same character in receiver and comparing them as it also equals to 'A' or not. If is equal to 'A' then turn ON the LED (PORTB.B3 pin).
I need your help i don't know what is the problem in code. I tried so much but nothing happened.
Here is the Code.
NRF24L01_16F73.c
*   nRF24L01
*   PIC16F73
#define RX_mode                  // define TX_mode or RX_mode
//#define chn 83
#include "nRF24L01.h"
#ifdef RX_mode
sbit LED at PORTB.B3; sfr;
sbit LED_tris at TRISB.B3; sfr;
#endif
#ifdef TX_mode
sbit LED1 at PORTB.B4; sfr;
sbit LED1_tris at TRISB.B4; sfr;
#endif
const char test[] = "A";
// Pipe Addresses
// adr0 should be unique
// adr1 through adr5 must differ only in the lowest significant byte
// Bytes are arranged lowest to highest
const char adr0[] = {0x78,0x78,0x78,0x78,0x78};    // LSB first
const char adr1[] = {0xf1,0xb4,0xb5,0xb6,0xb3};
const char adr2[] = {0xb3,0xb4,0xb5,0xb6,0xb3};
const char adr3[] = {0x83,0xb4,0xb5,0xb6,0xb3};
const char adr4[] = {0xcf,0xb4,0xb5,0xb6,0xb3};
const char adr5[] = {0x75,0xb4,0xb5,0xb6,0xb3};
char Data_In[1], stat;
char  Data_Out[1] = {'A'};
short dataLength = 1;
int hbyte;
// You can change these pins as long as your microcontroller supports SPI on the required pins
sbit Irq_pin   at PORTB.B2; sfr;
sbit Mosi_pin  at PORTC.B5; sfr;
sbit Ce_pin    at PORTB.B0; sfr;
sbit Sclk_pin  at PORTC.B3; sfr;
sbit Csn_pin   at PORTB.B1; sfr;
sbit Miso_pin  at PORTC.B4; sfr;
sbit Irq_tris  at TRISB.B2; sfr;  //input
sbit Mosi_tris at TRISC.B5; sfr;  // output
sbit Ce_tris   at TRISB.B0; sfr;  //output
sbit Sclk_tris at TRISC.B3; sfr;  //output
sbit Csn_tris  at TRISB.B1; sfr;  //output
sbit Miso_tris at TRISC.B4; sfr;  //input
// I use a procedure for any delay that is used more than once
void Comm_Delay() {Delay_us(10);}       // You can experiment with this delay
void Delay_10()   {Delay_ms(10);}
void Delay_100()  {Delay_ms(100);}
void Delay_500()  {Delay_ms(500);}
void Clear_Data(char dat[]){
     char i;
     for(i=0;i<dataLength;i++)dat[i] = ' ';
void toggleCSN(){
     Csn_pin = 1;
     Delay_us(20);                      // You can experiment with this delay
     Csn_pin = 0;
     Comm_Delay();
char Get_Status(){
     char s;
     Ce_pin = 0;
     toggleCSN();
     SPI1_Write(STATUS);
     Comm_Delay();
     s = SPI1_Read(NOP);
     Comm_Delay();
     Csn_pin = 1;
     return s;
char *getConst(char dest[], const char source[]){
    int i = 0;
    while (source[i])                  // while (source[i] != '\0')
    {dest[i] = source[i]; i++;}
    dest[i] = '\0';
    return dest;
char Get_FIFO_Flags(){
     char s;
     Ce_pin = 0;
     toggleCSN();
     SPI1_Write(FIFO_STATUS);
     Comm_Delay();
     s = SPI1_Read(NOP);
     Comm_Delay();
     Csn_pin = 1;
     s = 'A';
     return s;
void makeMsg(){                        // Put your data in here
     Clear_Data(Data_Out);
     getConst(Data_Out, test);
char readBuffer(){
     char i, s,y;
     Ce_pin = 0;
     Clear_Data(Data_In);
     s = Get_FIFO_Flags();
     if((s & 2) != 0){
         toggleCSN();
         SPI1_Write(R_RX_PAYLOAD);
         for(i=0; i < dataLength; i++){Comm_Delay(); Data_In[i] = SPI1_Read(0); y = Data_In[0];}
         Comm_Delay();
     toggleCSN();
     SPI1_Write(FLUSH_RX);
     Comm_Delay();
     Csn_pin = 1;
     Ce_pin = 1;
     return y;
void sendBuffer(){
     char i, j;
     do{
         toggleCSN();
         SPI1_Write(STATUS | W_REGISTER);
         Comm_Delay();
         SPI1_Write(0xff);            //clear flags
         Comm_Delay();
         toggleCSN();
         SPI1_Write(FLUSH_TX);
         Comm_Delay();
         toggleCSN();
         SPI1_Write(W_TX_PAYLOAD);
         for(i = 0; i < dataLength; i++) {Comm_Delay(); SPI1_Write(Data_Out[i]);}
         Comm_Delay();
         Csn_pin = 1;
         Ce_pin = 1;
         Delay_10();
         j = (Get_Status() & 0x20);                     // keep trying until ack is received
     }while(j==0);
char init_Radio(){
       char i;
       Ce_pin = 0;                                      // must be in standby or power down to write
       Comm_Delay();
       toggleCSN();
       SPI1_Write(CONFIG | W_REGISTER);
       Comm_Delay();
       #ifdef RX_mode
       SPI1_Write(PRIM_RX + PWR_UP + 0x07);//CRCO + EN_CRC + 0x07);    // Receiver
       toggleCSN();
       SPI1_Write(EN_AA | W_REGISTER);
       Comm_Delay();
       SPI1_Write(ENAA_P0 + ENAA_P1 + ENAA_P2 + ENAA_P3 + ENAA_P4 + ENAA_P5);
       Comm_Delay();
       toggleCSN();
       SPI1_Write(EN_RXADDR | W_REGISTER);
       Comm_Delay();
       SPI1_Write(ERX_P0 + ERX_P1 + ERX_P2 + ERX_P3 + ERX_P4 + ERX_P5);
       Comm_Delay();
       #endif
       #ifdef TX_mode
       SPI1_Write(PWR_UP + 0x07);//CRCO + EN_CRC + 0x07);              // Transmitter
       Comm_Delay();
       toggleCSN();
       Comm_Delay();
       SPI1_Write(ENAA_P0);
       Comm_Delay();
       toggleCSN();
       Comm_Delay();
       SPI1_Write(ERX_P0);
       Comm_Delay();
       toggleCSN();
       SPI1_Write(RX_ADDR_P0 | W_REGISTER);
       for(i=0;i<5;i++){Comm_Delay(); SPI1_Write(adr0[i]);} // This is the pipe in use by this transmitter
       Comm_Delay();
                                                            // The addresses above and below must be the same
       toggleCSN();                                         // Choose any of the 6 addresses used by the receiver
       SPI1_Write(TX_ADDR | W_REGISTER);
       Comm_Delay();
       #endif
       toggleCSN();
       SPI1_Write(SETUP_AW | W_REGISTER);
       Comm_Delay();
       SPI1_Write(AW5);
       Comm_Delay();
       toggleCSN();
       SPI1_Write(SETUP_RETR | W_REGISTER);
       Comm_Delay();
       SPI1_Write(0xfaf);
       Comm_Delay();
       toggleCSN();
       SPI1_Write(RF_CH | W_REGISTER);
       Comm_Delay();
       SPI1_Write(83);                                      // Set your channel here. Obviously it must be the same for TX and RX.
       Comm_Delay();
       toggleCSN();
       SPI1_Write(RF_SETUP | W_REGISTER);
       Comm_Delay();
       SPI1_Write(RF_PWR + LNA_HCURR);
       Comm_Delay();
       #ifdef RX_mode
       toggleCSN();
       Comm_Delay();
      /* toggleCSN();
       SPI1_Write(RX_ADDR_P1 | W_REGISTER);
       for(i=0;i<5;i++){Comm_Delay(); SPI1_Write(adr1[i]);}
       Comm_Delay();
       toggleCSN();
       SPI1_Write(RX_ADDR_P2 | W_REGISTER);
       for(i=0;i<5;i++){Comm_Delay(); SPI1_Write(adr2[i]);}
       Comm_Delay();
       toggleCSN();
       SPI1_Write(RX_ADDR_P3 | W_REGISTER);
       for(i=0;i<5;i++){Comm_Delay(); SPI1_Write(adr3[i]);}
       Comm_Delay();
       toggleCSN();
       SPI1_Write(RX_ADDR_P4 | W_REGISTER);
       for(i=0;i<5;i++){Comm_Delay(); SPI1_Write(adr4[i]);}
       Comm_Delay();
       toggleCSN();
       SPI1_Write(RX_ADDR_P5 | W_REGISTER);
       for(i=0;i<5;i++){Comm_Delay(); SPI1_Write(adr5[i]);}
       Comm_Delay();
       toggleCSN();
       Comm_Delay();
      /* toggleCSN();
       SPI1_Write(RX_PW_P1 | W_REGISTER);
       Comm_Delay();
       SPI1_Write(dataLength);
       Comm_Delay();
       toggleCSN();
       SPI1_Write(RX_PW_P2 | W_REGISTER);
       Comm_Delay();
       Comm_Delay();
       toggleCSN();
       SPI1_Write(RX_PW_P3 | W_REGISTER);
       Comm_Delay();
       Comm_Delay();
       toggleCSN();
       SPI1_Write(RX_PW_P4 | W_REGISTER);
       Comm_Delay();
       Comm_Delay();
       toggleCSN();
       SPI1_Write(RX_PW_P5 | W_REGISTER);
       Comm_Delay();
       Comm_Delay();*/
       #endif
       toggleCSN();
       SPI1_Write(RX_PW_P0 | W_REGISTER);
       Comm_Delay();
       Comm_Delay();
       Csn_pin = 1;
       i = Get_Status();
       return i;
void main(){
       char txt[5], dat1;
      // ADCON1 = 0x04;                           // digital not analog
      // CMCON = 7;                               // Comparators off
       //PORTA = 0;
       //TRISA = 0;                               // outputs
       Csn_tris = 0;
       #ifdef RX_mode
       LED_tris = 0;
       #endif
       #ifdef TX_mode
       LED1_tris = 0;
       #endif
       Csn_pin = 1;
       Ce_tris = 0;
       Ce_pin = 0;                              // 1 = listen or transmit
       SPI1_Init();
       //SPI1_Init_Advanced(_SPI_MASTER_OSC_DIV16, _SPI_DATA_SAMPLE_MIDDLE, _SPI_CLK_IDLE_LOW, _SPI_LOW_2_HIGH);
           Delay_ms(200);
       stat = init_Radio();
       #ifdef TX_mode
      // Clear_Data(Data_Out);
       #endif
       do {
           dat1 = 0;
           dat1 = Get_FIFO_Flags();
           #ifdef TX_mode
           Delay_100();
         //  makeMsg();
           sendBuffer();
           Delay_100();
           if(irq_pin == 0) LED1 = 1;
           else LED1 = 0;
           #endif
           #ifdef RX_mode
           Ce_pin = 1;
           dat1 = readBuffer();
           hbyte = (char)dat1;
           if(hbyte == 0x41) LED = 1;
           else LED = 0;
           if((dat1 & 2) != 0) LED = 1;
           else LED = 0;
           if(dat1 == 'A') LED = 1;
           else LED = 0;
              Ce_pin = 0;
           toggleCSN();
           Comm_delay();
           Ce_pin = 1;
           Delay_500();
           #endif
       }while(1);
and here is nRF24L01.h
/* Memory Map */
#define CONFIG      0x00
#define EN_AA       0x01
#define EN_RXADDR   0x02
#define SETUP_AW    0x03
#define SETUP_RETR  0x04
#define RF_CH       0x05
#define RF_SETUP    0x06
#define STATUS      0x07
#define OBSERVE_TX  0x08
#define CD          0x09
#define RX_ADDR_P0  0x0A
#define RX_ADDR_P1  0x0B
#define RX_ADDR_P2  0x0C
#define RX_ADDR_P3  0x0D
#define RX_ADDR_P4  0x0E
#define RX_ADDR_P5  0x0F
#define TX_ADDR     0x10
#define RX_PW_P0    0x11
#define RX_PW_P1    0x12
#define RX_PW_P2    0x13
#define RX_PW_P3    0x14
#define RX_PW_P4    0x15
#define RX_PW_P5    0x16
#define FIFO_STATUS 0x17
#define DYNPD       0x1C
#define FEATURE     0x1D
/* Bit Mnemonics */
#define MASK_RX_DR  0x40 //6
#define MASK_TX_DS  0x20 //5
#define MASK_MAX_RT 0x10 //4
#define EN_CRC      0x08 //3
#define CRCO        0x04 //2
#define PWR_UP      0x02 //1
#define PRIM_RX     0x01 //0
#define ENAA_P5     0x20 //5
#define ENAA_P4     0x10 //4
#define ENAA_P3     0x08 //3
#define ENAA_P2     0x04 //2
#define ENAA_P1     0x02 //1
#define ENAA_P0     0x01 //0
#define ERX_P5      0x20 //5
#define ERX_P4      0x10 //4
#define ERX_P3      0x08 //3
#define ERX_P2      0x04 //2
#define ERX_P1      0x02 //1
#define ERX_P0      0x01 //0
#define AW3         0x01 //0     3 bytes
#define AW4         0x02 //0     4 bytes
#define AW5         0x03 //0     5 bytes
#define ARD         0x00 //4
#define ARC         0x01 //0
#define PLL_LOCK    0x10 //4
#define RF_DR       0x08 //3
#define RF_PWR      0x06 //6
#define RX_DR       0x40 //6
#define TX_DS       0x20 //5
#define MAX_RT      0x10 //4
#define RX_P_NO     0x02 //1
#define TX_FULL     0x01 //0
#define PLOS_CNT    0x10 //4
#define ARC_CNT     0x01 //0
#define TX_REUSE    0x40 //6
#define FIFO_FULL   0x20 //5
#define TX_EMPTY    0x10 //4
#define RX_FULL     0x02 //1
#define RX_EMPTY    0x01 //0
#define DPL_P5      0x20 //5
#define DPL_P4      0x10 //4
#define DPL_P3      0x08 //3
#define DPL_P2      0x04 //2
#define DPL_P1      0x02 //1
#define DPL_P0      0x01 //0
#define EN_DPL      0x04 //2
#define EN_ACK_PAY  0x02 //1
#define EN_DYN_ACK  0x01 //0
/* Instruction Mnemonics */
#define R_REGISTER    0x00
#define W_REGISTER    0x20
#define REGISTER_MASK 0x1F
#define ACTIVATE      0x50
#define R_RX_PL_WID   0x60
#define R_RX_PAYLOAD  0x61
#define W_TX_PAYLOAD  0xA0
#define W_ACK_PAYLOAD 0xA8     // and with ack pipe number
#define FLUSH_TX      0xE1
#define FLUSH_RX      0xE2
#define REUSE_TX_PL   0xE3
#define NOP           0xFF
/* Non-P omissions */
#define LNA_HCURR   0x01 //0
/* P model memory Map */
#define RPD         0x09
/* P model bit Mnemonics */
#define RF_DR_LOW   0x10 //5
#define RF_DR_HIGH  0x08 //3
#define RF_PWR_LOW  0x02 //1
#define RF_PWR_HIGH 0x06 //2
