Hello all,
I am instantiating an nport inside a VerilogA module and I map the pins of the module to the corresponding ports.
The nport is reading an .s2p file that has been produced from the SP analysis of a schematic ( a filter ).
I am adding the file as input to the nport and then use SP analysis, expecting the get exactly the same results as the ones of the schematic simulation.
However, the results are not correct :
1) It seems like the information of the output impedance is lost when I am mapping the ports because when I add a load at the output the S21 parameter doesn't change at all.
2) S22 parameter also gives a constant 0 db which of course is not the case.
I suspect that the mapping of the ports of the nport instance to the module's pins is implemented by an ideal VCVS (??) resulting in 0 output impedance.
Anyone has encountered something like that or has any suggestions?
You are right, if I map the ports to the pins of the module I get the correct S params.
The thing is that I need to map the ports firstly in some internal nodes ,which will be the inputs of a polynomial and the output of the polynomial will be the final output ( I am attaching a screenshot of the VerilogA code):
In that way I am trying to model the nonlinearities of the actual circuit
Can you be a bit more specific about the calculation of a1,a2,b1,b2 and how will that help me?
I would also prefer not to use S params but there is no other way as far as I know to properly model my schematic.
If you know any other way, feel free to suggest
I am just starting to model with VerilogA, so I would need a bit of more specific advice.
The file generated from SP analysis can indeed be written as Z,Y,S parameters but how will this help?
I understand that it is a linear black box, but how can I cascade correctly another black box that introduces non-linearities? Or it is just not possible?
If you mean the difference between input/output and inout ports , I think i do. But for the specific model, the ports are unidirectional.
I am thinking in terms of block diagrams :
The first block is the nport and it is cascaded with another block that clips the output according to a specified IIP3. At the final output , I want to measure the same S11,S12,S21,S22 that I measure at the output of the first block ( the nport ).
I have read about how to model nonlinear RF blocks, but on all occasions the S parameters where passed to the model as a constant value , e.g S21=5dB.
However,S21 varies over frequency and I want to include this frequency dependency.
