Not getting adc value correctly
cnandha19
Member level 3
#include<htc.h>
#include<pic.h>
//Config word
__CONFIG(FOSC_INTOSC & WDTE_OFF   & PWRTE_ON & MCLRE_OFF & BOREN_ON & CP_OFF & CPD_OFF);
//Internal clock oscillator & Watchdog timer off & Master clear reset & brown out protection on & CODE PROTECTION _OFF & DATA CODE PROTECTION BIT_OFF
// Define LED pin
// Define CPU Frequency
// This must be defined, if __delay_ms() or
// __delay_us() functions are used in the code
#define _XTAL_FREQ   8000000
#define BUZZER   LATA0
#define REDLED   LATA1
#define GREENLED LATA5    //RA5 connected
//Sensor connected across RA2
#define BAUDRATE 9600
unsigned int ADC_Value;
void InitADC(void)
	ADCON1  = 0x80;	     // Make PORTA and PORTE analog pins
	TRISA   = 0x04;      // Make RA5, RA3, RA2, RA1, RA0 input
	ADCON0  = 0x81;		 // Turn on the A/D Converter
unsigned int GetADCValue(unsigned char Channel)
	ADCON0 = 0x00;         // Clear Channel selection bits
	ADCON0 |= (Channel<<3); // Select channel pin as ADC input
    __delay_ms(50);         // Time for Acqusition capacitor
							// to charge up and show correct value
	GO_nDONE  = 1;		    // Enable Go/Done
	while(GO_nDONE);        // Wait for conversion completion
	return ((ADRESH<<8)+ADRESL);   // Return 10 bit ADC value
void InitUART(void)
	TRISA4 = 1;   					// TX Pin
	//TRISC7 = 1;   					// RX Pin
	SPBRG = ((_XTAL_FREQ/16)/BAUDRATE) - 1;
	BRGH  = 1;                   	// Fast baudrate
	SYNC  = 0;						// Asynchronous
	SPEN  = 1;						// Enable serial port pins
	CREN  = 1;						// Enable reception
	SREN  = 0;						// No effect
	TXIE  = 0;						// Disable tx interrupts
	RCIE  = 1;						// Enable rx interrupts
	TX9   = 0;						// 8-bit transmission
	RX9   = 0;						// 8-bit reception
	TXEN  = 0;						// Reset transmitter
	TXEN  = 1;						// Enable the transmitter
void SendByteSerially(unsigned char Byte)  // Writes a character to the serial port
	while(!TXIF);  // wait for previous transmission to finish
	TXREG = Byte;
void SendStringSerially(const unsigned char* st)
	while(*st)
		SendByteSerially(*st++);
// Main function
void main()
    TRISA=0x04; //0x000000    Set PORTA as output PORT
    LATA=0x00;
    ANSELA=0x04;
    OSCCON=0x69;
	while(1)
    void InitADC(void);
    unsigned int GetADCValue(unsigned char);
    InitADC();
    InitUART;
    ADC_Value = GetADCValue(AN2);
    BUZZER=1;
    __delay_ms(1000);
    REDLED=1;
    GREENLED=1;
    __delay_ms(1000);
     BUZZER=0;
     REDLED=0;
     GREENLED=0;
Why did you keep initialization functions (InitADC(),InitUART() etc.) ? It should be called once.
The program should be
void main()
    LATA=0x00;
    ANSELA=0x04;
    OSCCON=0x69;
    InitADC();
    InitUART;
	while(1)
    BUZZER=1;
    __delay_ms(1000);
    REDLED=1;
    GREENLED=1;
    __delay_ms(1000);
     BUZZER=0;
     REDLED=0;
     GREENLED=0;
