[SOLVED] Normalize to fixed impedance 50 Ohm. CST
Fovakis
Full Member level 1
Greece,Athens
Is anyone here can help me what this means??
What is the differencec with or without it?
thanks a lot :evil:
V
volker_muehlhaus
This is related to the Z0 problem in your other post.
For wave guide ports, some 3D simulators define Z0 as line impedance at the port ("generalized S-parameters"). This means that any straight line will have perfect match, no matter what the dimensions are. However, the simulator does know that Z0 value and can re-normalize the S-parameters to 50 ohm port impedance. This is what the switch does: it allows you to switch between generalized S-parameters and 50 Ohm S-parameters.
Fovakis
Full Member level 1
Greece,Athens
I almost understand what you mean my friend, but i need an example.
Icase_Without normalize to 50Ohm, for e=2 and some specific dimensions, a waveguide port gives |s11|=0,40 phase=93degrees and |Zin|=|0.29+i2591|=2591Ohm with phase=89 ,also VSWR=2,31.
IIcase_With normalize to 50Ohm the same one is::lol: |s11|=0,94 with phase=14degrees, and |Zin|=|0.39+i2591|=2591 ohm and phase=89, also VSWR=36,13 8-O.
As we can see the Zin impedance of the waveguide did't change cause i didn't changed any of the materials and the dimensions.
But the S11 changed much and i don't understand it.The formula s11=Zin-Zo/Zin+Z0 for s11,Zin complex numbers
is it right for each case?
V
volker_muehlhaus
Yes, exactly.
If you now calculate the S11 value for your chosen reference impedance Z0, that S11=(Zin-Z0)/(Zin+Z0) will depend on the value of Z0.
Fovakis
Full Member level 1
Greece,Athens
Yes, exactly.
Can you please explain mathematicaly the numbers of s11,phase,Zin and Zo that i have write above?:evil:
Fovakis
Full Member level 1
Greece,Athens
hehe it is not that i am boring bro. It is that the numbers with "normalize to 50" ,for |s11|=0,94 with phase=14degrees, and |Zin|=|0.39+i2591|=2591 ohm and phase=89 ARE WRONG. If you take these numbers and search for Zo you will not have 50. That's my question . WHY?
V
volker_muehlhaus
Ok, I see what you mean.
You should contact CST support to find out.
Fovakis
Full Member level 1
Greece,Athens
I will go ask my professor at the university...i he don't know i will ask support team! Thanks a lot for all!:)
eraste
France
Hello,
Between the Z and S matrix the relation is not as simple as you write. You can not write that S11 = (Z11-Zo)/(Z11+Zo). Have a look at a HF book to see the relations. In fact you find that :
Z11 = Zo ((1+S11)(1-S22)+S12*S21)/((1-S11)(1-S22)-S12*S21))
And so on for the others parameters.
Fovakis
Full Member level 1
Greece,Athens
ok...so...the exression Z11 where is refering to? I understand at the resistance of the waveguide at the port I, right?!
V
volker_muehlhaus
@eraste: You are correct for Z11, but this is not what we discussed. Zin is the input impedance into port 1 with the other ports terminated.
Fovakis
Full Member level 1
Greece,Athens
@Volker. Yes but CST produces Z11,Z21 not Zin :O! The Zin how do we calculated from Cst? All the above at my posts that i have write about Zin are reffering for Z11.
So if the formula of eraste is correct for the determination of Z11 we need not only s11, but s21,s22,s12 !!!
volker are you running Cst or HFSS or both?
Thanks for the company bro :)
eraste
France
The waveguide is seen like "quadrupole" . Between the S matrix (S11 S12 S21 S22) and the Z matrix (Z11 Z12 Z21 Z22) , we have not the relation Z11 = Zo (1+S11)/(1-S11).
Refer at any book deal with filter or scatering parameters. This latest relation is true only for "dipole".
Fovakis
Full Member level 1
Greece,Athens
@eraste!can you make any attachment of the notes you have about it?
So for my restrangular waveguide Z11 = Zo ((1+S11)(1-S22)+S12*S21)/((1-S11)(1-S22)-S12*S21))
is ok?>!
