Re: "Normal"/Industrial Ethernet. What is the diff
It s impossible to give a simple answer so you can find many different
version of industrial ethernet (in fact each PLC company has it s own industrial ethernet protocol)
The big problem of Ethernet/TCPIP is the lacking of determinism compared to other industrial networks. Collisions are not really a problem on a computer network but if you want to send an information to
another industrial component you have sometimes to be sure it gets the information
within a certain time (real time). Ethernet TCPIP cannot do that.
So companies are working on "industrial ethernet" which means increase
determinism or leaving TCPIP tring to get a real time Ethernet
Hi
yes as it was pointed out .The only difference is the cable BUT ALSO The connector .. suppose that those cables are present in a flamable gas enviroment .. .. So there are several types of solutions .
