NOR FLASH Controller in vhdl
kapsy_27
Newbie level 3
Newbie level 3
Pune
I want to write a flash controller for s70gl02gp spanson NOR Flash in VHDL. Please can any body provide me with the code if any body have already written it or have any example code for a parallel NOR Flash in vhdl.
Many Thanks
kapsy.
If you are interfacing NOR flash with the Xilinx FPGAs then Xilinx tolls supports this we don't need to write..
Ya I hv checked but its in Verilog with WB bus interface.
I am using Xilinx FPGA. Where is the option for it in Xilinx ISE.
Not in ISE use EDK to add NOR flash controller and after adding the controller change the timing parameters based on your device..
Thanks for the quick response:smile:
