Non zero steady state error
garimella
Full Member level 5
I have transfer function
T.F = 130s+130/s^3+ 10s^2+130s+130. A step input does not give a zero steady state error . This system is a type2 and some how contradicts the theory. Any body can explain why?
First of all is not a type 2, and second of all your transfer function does not even exist, so I think it is a typo.
No, it is not a typo, open loop TF= (130/s^2) *(s+1)/(s+10), closed loop TF = 130s+130/s^3+ 10s^2+130s+130
If you want someone else to understand what your are writing, use at least standard programming writing of mathematical expressions.
Closed Loop TF (unity feedback) = (130s+130)/(s^3+ 10s^2+130s+130)
Your closed loop TF corresponds to a type 0, nevertheless it has no position error. Kp->infinite and hence position error is zero. You can arrive to the same conclusion using the closed loop TF where the steady state output follows the step input.
