Non-Multiplexed Digital Clock Needed
burbing
Newbie level 2
Hi there all,
I have a project for driving 40W 120V AC lamps with the means of a digital clock's LED voltages of 1.7V DC. I had Sharp S202S02 relays for this purpose. The problem is about the digital clock that I've used. It has a strobe effect in 7 segment LEDs, like multiplexed drive. I got my AC lamps driven like 20Hz or something flickering, that I discovered in the LED's voltage measurement. It was changing all the time when the lamps are to be turned on and off. I need 0V DC while the LEDs are turned off.
My question is: where can I find such a non-multiplexed digital clock?
Any help would be appreciated..
Burak.
I'm not sure if any non-multiplexed clock chips exist.
How about using a microcontroller, CPLD, or FPGA that has enough output pins to directly control all your segment drivers? Do you have experience programming those devices?
actually, I didn't experience before.
If the seven segment data is updated before the digit selection pulse, you can use the digit selection pulse to separate the segment outputs into latches and then drive your display. If you do not have experience, may be you can take the help of an Engineering student and get it done.
It also may not be difficult for you to get a new clock developed throuch an engineering student, you can even think of sponsoring it as a miniproject to an Engineering College.
Regards,
Laktronics
what about using triac in place of relay
both costs the same
Nandhu
