DeboraHarry
Full Member level 5
I want to temporarily "delete" some objects from my HFSS model, so they play no part. Can I do that by just making the object non-model, then converting it back to model if I want to include it later?
The manual says:
If you want to create an object that does not affect the geometric model, define the object as non model. This ensures that the object is used for analysis only; it will not affect the solution process. After drawing the non-model object, assuming it lies in the problem region, you can use it in the reporter as a place on which to plot field quantities. For example, draw a non-model line across the design, then (in the reporter) plot Mag_E on every point along that line.
which I think indicates it can do what I want, but I'm not 100% sure, since my non-model object wont be a line, but a conductor or dielectric.
Deborah
The manual says:
Deborah
