Hi ,,,
I hope every body are OK, well, how to simulate the noise using Cadence Spectre?
I want to simulate the noise sources effects on differential amplifier performance , so, the NMOS noise, tail current, and the load (passive or active) are considered. so what is the procedure?
thankx
choose noise analysis and choose the output node (on which u need to measure the noise), then choose the input source of noise (which is noiseless), then run noise analysis
