Noise simulation of OPAmp
deep_sea
Hi Guys,
I am simulating the noise performance of an opamp. I would like to check if my setup is correct.
The opamp is a two stage miller compensated opamp. The input is a DC + AC small signal.
The WP1 variable is the number of PMOS input transistors and is related to the length of input transistor. For example WP1=48, means W1=48um, L1=1u, WP=480 means W1=480um and L1=10um
According to the following expression: e2n =B/(f*W1*L1), it is expected that input referred noise would be 100 smaller when W1 and L1 are increased 10 times each. In simulation you can see in attachment it has almost no effect.
Could you please check if the simulation setup for noise is correct? does anyone has an explanation?
Do you have a closed loop around this amplifier?
If you print the noise sources at 100 Hz, is the input transistor dominating?
