Noise Simulation of OP AMP with Cadence Spectre
chiara
Member level 2
spectre noise simulation
hi,
can anyone tell me how to do noise simulation of differential input to differential output op amp with cadence spectre?
is there any material that tells how to do this?
thanks.
elbadry
Full Member level 6
Egypt
input-referred noise spectre simulation
I am not quite sure:
You can do a noise simulation ( with resistor feedback equal to ur gaun factor ) and get output noise ( I assume u want differntial output noise )
Divide by the feedback gain to get the noise referred to the input of ur circuit
gunturikishore
Full Member level 2
INDIA GANDHINAGAR
spectre noise simulation -phase
I think use of Vsource is more useful in noise simulations. You can directly get input referred noise. I did in this method long back after suggestion from Cadence support and dont know about the new version changes.
gingerjxb
Member level 2
noise simulation spectre
my method is to input differential noise source(using vdc(ac=1) and vcvs), use noise analysis to simulate. output noise selects voltage, and input noise is port. after simulation, use results in ADE to check input-referred or output-referred noise, or calculate noise power in a band.
ames_1
Newbie level 3
op amp cadence simulation
Any possible simulation manual in this specific topic?
walker5678
Full Member level 3
opamp noise simulation
What is a Vsource method ? Could anyone explain it more?
thanks!
walker5678
Full Member level 3
simulate op amp noise using cadence
But i did not find the "vsource" instance. I am using Cadence IC5033.
