expert_vision
Junior Member level 3
Noise due to ground coupling
I am trying to measure the current in the mains trough a shunt resistor by amplifying the voltage across it with an op amp and feed it into a microcontroller's ADC, like in the schematics below.
If I connect a high impedance load in the mains everything is OK, but if I connect a low impedance one, the uC resets due to huge spikes in the ground, no matter how much I try to stabilize the Vcc at the uC.
How to filter this huge spikes coming through the ground from the mains when a load is connected?
