Hi there,
I would like to compare two transistors, to replace a nearly obsolete reference in a design.
The first one (the reference) has a noise density of 1nV/sqrt(Hz). We can consider that the noise density is flat on the usefull bandwith, i.e. 10Hz-> 15kHz (not true, but a worst case).
The second transistor has a noise figure of 2.8 dB on the same bandwidth.
How can I compare the noise on these two transistors ? I am quite stuck with the noise figure concept...
Regards,
RG
