no waveform appear in modelsim
nursafirah
Newbie level 6
Newbie level 6
i have done the test bench and what so ever.. but my problem is my waveform can't run or generate the wave.. what should i do?
this is my coding.
-- Purpose : compress the bit
-- After reset signal, it will compress the bit output
--input = 001000110 11110000 11011010 00000001 11111010 01101100 00000001 00001000 (64 bit)
--LUT = 00100110 = 00, 11111010 = 01, 01101100 = 10, 00000001 = 11
--output last = 00 11110000 11011010 11 01 10 11 00001000 (33 bit)
library ieee;
use ieee.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
use ieee.numeric_std.all;
entity compression is
port (	clk			: in std_logic;
	bitout1, bitout4  : buffer std_logic_vector(1 downto 0);
	bitout2, bitout3	: buffer std_logic_vector(7 downto 0);
	bitin				   : in std_logic_vector (31 downto 0);
	concat_out 			: out std_logic_vector (19 downto 0));
--	a,b,c,d,e,f,g,h									  : in std_logic_vector (7 downto 0);
--   busy				   								  : in std_logic;                        --for clock is '1'
--   not_ready_a 										  : out std_logic;                      --for clock is '0'
--   not_ready_b 										  : out std_logic;
--   not_ready_c 										  : out std_logic;
--   not_ready_d 										  : out std_logic);
 --  not_ready_e 											  : out std_logic;
--   not_ready_f 											  : out std_logic;
--   not_ready_g 											  : out std_logic;
 --  not_ready_h 											  : out std_logic);
end compression;
-----------------------architecture begin-----------------------------------------
architecture SAFIRAH of compression is
	signal conca : std_logic_vector (19 downto 0);
   signal a,b,c,d: std_logic_vector (7 downto 0);
BEGIN
process (clk,a)
begin
if (clk='1' and clk'event) then  --clock
		a <= bitin (31 downto 24);
		if (a <= "00100110") then
		   bitout1 <= "00";
		elsif (a = "11111010") then
			bitout1 <= "01";
		elsif (a = "01101100") then
			bitout1 <= "10";
		elsif (a = "00000001") then
			bitout1 <= "11";
	--	else
		--(a = std_logic_vector (63 downto 56) <= (others => '-') then
		--	bitout1 (63 downto 56) <= a;
   	end if;
		end if;
	--	end if;
	end process;
process (clk,b)
begin
	 b <= bitin (23 downto 16);
	 if (b <= "11110000") then
	     bitout2 <= "11110000";
	--if (b <= "00100110") then
		--   bitout2 <= "00";
		--elsif (b <= "00100110") then
			--bitout2 <= "01";
			--bitout2 <= "10";
			--bitout2 <= "11";
	   --else
		--bitout2 <= "111100000";
		end if;
		end if;
	--	end if;
	end process;
process (clk,c)
begin
	  c <= bitin (15 downto 8);
		if (c <= "11011010") then
			bitout3 <= "11011010";
	--if (c <= "00100110") then
		--   bitout3 <= "00";
	--	elsif (c <= "00100110") then
		--	bitout3 <= "01";
		--elsif (c <= "00100110") then
		--	bitout3 <= "10";
		--	bitout3 <= "11";
	--	else
		--	bitout3 <= s;
		end if;
	  end if;
	--	end if;
	end process;
process (clk,d)
begin
  d <= bitin (7 downto 0);
	if (d <= "00100110") then
		   bitout4 <= "00";
		elsif (d <= "11111010") then
			bitout4 <= "01";
		elsif (d <= "01101100") then
			bitout4 <= "10";
		elsif (d <= "00000001") then
			bitout4 <= "11";
--		else
		--	bitout4 <= s;
		end if;
		end if;
	--	end if;
	end process;
--process (clk,e)
--begin
--if rising_edge (clk) then
--if (busy = '1') then
--	not_ready_e <= '0';
--	e <= bitin (31 downto 24);
	--if (e <= "00100110") then
	--	   bitout5 <= "00";
	--	elsif (e <= "00100110") then
	--		bitout5 <= "01";
	--		bitout5 <= "10";
	--		bitout5 <= "11";
	--   else
		--	bitout5 <= s;
--		end if;
--		end if;
--		end if;
--	end process;
--process (clk,f)
--begin
--	not_ready_f <= '0';
--	f <= bitin (23 downto 16);
--	if (f <= "00100110") then
--		   bitout6 <= "00";
--		elsif (f <= "00100110") then
--			bitout6 <= "01";
--		elsif (f = "00100110") then
--			bitout6 <= "10";
--			bitout6 <= "11";
--	   else
		--	bitout6 <= s;
--		end if;
--		end if;
--		end if;
--	end process;
--process (clk,g)
--begin
--	if (busy = '1') then
--		not_ready_g <= '0';
--	g <= bitin (15 downto 8);
--	   if (g <= "00100110") then
--		   bitout7 <= "00";
--		elsif (g <= "00100110") then
--			bitout7 <= "01";
--			bitout7 <= "10";
--			bitout7 <= "11";
--	   else
		--	bitout7 <= s;
--		end if;
--		end if;
--		end if;
--	end process;
--process (clk,h)
--begin
--		not_ready_h <= '0';
--	h <= bitin (7 downto 0);
--	if (b <= "00001000") then
	--		bitout8 <= "00001000";
	--if (h <= "00100110") then
	--	   bitout8 <= "00";
	--	elsif (h <= "00100110") then
		--	bitout8 <= "01";
	--		bitout8 <= "10";
	--		bitout8 <= "11";
	--	else
		--	bitout8 <= s;
	--	end if;
	--	end if;
	--	end if;
--	end process;
---------------------concatenation---------------------------------
 conca <= bitout1  & bitout2 & bitout3 & bitout4;
 concat_out <= conca;
end architecture SAFIRAH;
and this is my testbench code...
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY compression_vhd_tst IS
END compression_vhd_tst;
ARCHITECTURE compression_arch OF compression_vhd_tst IS
-- constants
-- signals
SIGNAL bitin : STD_LOGIC_VECTOR(31 DOWNTO 0);
SIGNAL bitout1 : STD_LOGIC_VECTOR(1 DOWNTO 0);
SIGNAL bitout2 : STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL bitout3 : STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL bitout4 : STD_LOGIC_VECTOR(1 DOWNTO 0);
SIGNAL clk : STD_LOGIC := '0';
SIGNAL concat_out : STD_LOGIC_VECTOR(19 DOWNTO 0);
COMPONENT compression
	PORT (
	bitin : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
	bitout1 : BUFFER STD_LOGIC_VECTOR(1 DOWNTO 0);
	bitout2 : BUFFER STD_LOGIC_VECTOR(7 DOWNTO 0);
	bitout3 : BUFFER STD_LOGIC_VECTOR(7 DOWNTO 0);
	bitout4 : BUFFER STD_LOGIC_VECTOR(1 DOWNTO 0);
	clk : IN STD_LOGIC;
	concat_out : OUT STD_LOGIC_VECTOR(19 DOWNTO 0)
END COMPONENT;
BEGIN
	i1 : compression
	PORT MAP (
-- list connections between master ports and signals
	bitin => bitin,
	bitout1 => bitout1,
	bitout2 => bitout2,
	bitout3 => bitout3,
	bitout4 => bitout4,
	clk => clk,
	concat_out => concat_out
--	clk <= not clk after 10ns;
--clk_signal : PROCESS
BEGIN
		clk <= '0';
		wait for 10ns;
		clk <= '1';
		wait for 10ns;
	end process clk_signal;
--init : PROCESS
--BEGIN
	--	wait for 20ns;
	--	bitin	<= "00100110111100001101101000000001";
   --   wait for 20ns;
	--	wait for 20ns;
	--   wait for 20ns;
	--	wait for 20ns;
	--	wait for 20ns;
--WAIT;
--END PROCESS init;
END compression_arch;
and when i run the modelsim, the error has occur. this is my error. ** Error: (vsim-19) Failed to access library 'compression' at "compression".. what should i do to make it clear?
How are you running modelsim? You problem is with the vsim command line which is looking for a compression library. Your code doesn't require that library.
Regards
