[No title]
noobler
Member level 2
Pilipinas
Laser Soldering: minimum hole applicable and depth? :arrow:
Hi guys,
I need to ensure that the press fit pins are very stable by applying solder to it and the best method I can think of is laser soldering after SMT + Press-fitting the connector. Unfortunately the hole diameter is 0.3mm and depth of pins could be around 1mm at 2.34mm PCB thickness. Does anyone know if laser soldering can be done with such small drill hole? Considering that the solder can only be applied at the exit points of the press fit connectors (or pre apply the solder paste at the top connector side). Thanks for your reply and thoughts on this.
Regards,
Noobler :cool:
mpfisher
Newbie level 6
Glasgow
Re: Laser Soldering: minimum hole applicable and depth? :arrow:
Could you give us more details about the particular connector you intend to use?
In my opinion, soldering of press-fit connectors defeats their purpose. They are meant for solder-less application and provide much more reliable connection points than those of typical solder-down connectors.
There is a good read about press-fit connectors here:
https://www.te.com/content/dam/te-com/documents/automotive/global/whitepaper-pressfit-072014.pdf
Mattylad
Advanced Member level 3
Lancashire UK.
There is a good way to answer this, contact the people who make your PCB.
They will be best able to advise you what can and cannot be done, or perhaps who can do it if they cannot.
FvM
Super Moderator
Staff member
Bochum, Germany
I agree with mpfisher that the basic premise of the thread is wrong. Soldering can be appropriate after removal and reassembly of a press-fit component. Press-fit is considered as a kind of cold welding giving reliable interconnect, correct drill diameter presumed.
