no simulation for counter in modelsim!!!!
the_phoenix
Newbie level 6
Newbie level 6
modelsim tri1
hello..
i have this problem with a vhdl code when i try to simulate it in modelsim.
The code is for a simple counter ...link to it..
h**p://toolbox.xilinx.com/docsan/xilinx8/books/data/docs/xst/xst0018_5.html
when i try to run it in modelsim and force a value to "clear" i/p ,i get an o/p of "XX"...and hence no count is output.
whereas, when i make clr a clock, the count sequence is initiated.
plz help...it's urgent
That web page contains links to many examples. Which one?
I tried counters_1.vhd (inside examples_v7.zip), and it simulates just fine.
Apply a brief high reset pulse on CLR, then clock pulses on C.
The counter works fine..
after
vsim counters_1
type the following commands and let us know!
add wave sim:/counters_1/c
add wave sim:/counters_1/clr
add wave sim:/counters_1/q
force -freeze sim:/counters_1/c 1 0, 0 {50 ns} -r 100
force -freeze sim:/counters_1/clr 1 0 -cancel 10
run 100
force -freeze sim:/counters_1/clr 0 0 -cancel 10000
run 10000
thx for the prompt reply...i tried the high pulse on clr and it worked just liked u said it would.
however, i still have a problem 'cause the upcounter( 2bit in this case) is supposed to work as an input to a decoder(2to4) to generate a timing cycle sequence T0,T1,T2,T3.
Now,Clr signal is internally generated by the control logic of my project and i cant make it work as a short pulse.
(clr is generated when an operation is completed and hence is driven either high or low but not as a pulse)
I'd appreciate any help in this regard...thx anyway
Are you applying an external reset pulse to your FPGA/CPLD, or would you rather reset everything interally? I normally initialize all my registers in HDL, and don't use any reset pulses.
If you show us the troublesome part of your control logic, someone here can probably help you debug it.
wel...the clear signal i use is generated by completion of an instruction.
The project is a simple processor, implemented using the basic idea presented in morris mano "digital design"...where a timing decoder is used to generate a sequence of time cycles during which a given micro-instruction is completed.
Now, the clear is need to reset the counter feeding a decoder at the end of completion of instruction so tht, counter cud then start a seq for a new instruction cycle.
This clear is internal to my block ....i mean...the counter is a sub-file in my main project an i cant seem to make the counter without a pulse transition at clear.
To elaborate...if i set clear to 0 indication a count seq to be initiated , then i get a ZZZ count output.
However, if i make the count go manually from 1 to 0, the count cycle is initiated as reqd.
But since the clear is internal to my block, it is generated as a simple signal and not a pulse.
btw, i use a forcin clock in my test bench , which is external.
A guy suggested to me the idea of trying to generate a clock internal to the test becnh
plz think abt this and help me in any which way u can....
thx anyway
cheers...
Will you post ur code here?? So that we get clear picture of what u
want to do.
yeah..right ..i think i shud have done the first time itself...haha
ok...this is the link..it's a rapidshare link/..
it's actually a collection of all my project files....
proc is the main vhd file---my simple processor...
i havent included my test benches 'cause i dont think they r right anyway...
my problem is....i cannot write a test bench for proc and also my counter doesnt seem to work w/o a pulse type change.
thx anyway..
cheers
Here I modified ur code... The testbanch is also there... It works fine...
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_signed.all;
use work.all;
ENTITY proc IS
PORT( Data      : IN     STD_LOGIC_VECTOR(7 DOWNTO 0);
      Reset, w  : IN     STD_LOGIC;
      Clock     : IN     STD_LOGIC;
      F, Rx, Ry : IN     STD_LOGIC_VECTOR (1 DOWNTO 0);
      Done      : BUFFER STD_LOGIC;
      BusWires  : INOUT  STD_LOGIC_VECTOR(7 DOWNTO 0));
END proc;
ARCHITECTURE Behaviour OF proc IS
  component dec2to4
    Port (w : IN STD_LOGIC_VECTOR(1 DOWNTO 0);
          En : IN STD_LOGIC;
          y : OUT STD_LOGIC_VECTOR(0 to 3));
  end component;
  component regn
    generic (n:integer:=8);
	 Port ( R : in std_logic_vector(N-1 downto 0);
           Rin : in std_logic;
           Clock : in std_logic;
           Q : out std_logic_vector(N-1 downto 0));
  end component;
  component trin
    generic(n:integer:=8);
    Port ( X : in std_logic_vector(N-1 downto 0);
           E : in std_logic;
           F : out std_logic_vector(N-1 downto 0));
  end component;
  component  upcount
    Port (clear,clock : IN STD_LOGIC;
          Q            : BUFFER STD_LOGIC_VECTOR(1 DOWNTO 0)  );
  end component;
  SIGNAL Rin,Rout :  STD_LOGIC_VECTOR(0 TO 3);
  SIGNAL Clear, High, AddSub : STD_LOGIC;
  SIGNAL Extern, Ain, Gin, Gout, FRin : STD_LOGIC;
  SIGNAL Count : STD_LOGIC_VECTOR(1 DOWNTO 0);
  SIGNAL T, I, X, Y : STD_LOGIC_VECTOR(0 TO 3);
  SIGNAL R0, R1, R2, R3 : STD_LOGIC_VECTOR(7 DOWNTO 0);
  SIGNAL A, Sum, G : STD_LOGIC_VECTOR(7 DOWNTO 0);
  SIGNAL Func,FuncReg : STD_LOGIC_VECTOR(1 TO 6);
BEGIN
     High <= '1';
     Clear <= Reset OR Done OR (NOT w AND T(0));
     Counter : upcount port map (Clear,Clock,Count );
     decT : dec2to4 port map (Count, High, T );
     Func <= F & Rx & Ry;
     FRin <= w AND T(0);
     Functionreg :regn GENERIC MAP (N => 6 )
       PORT MAP ( Func, FRin, Clock, FuncReg );
     decI : dec2to4 PORT MAP (FuncReg( 1 TO 2 ), High, I );
     decX : dec2to4 PORT MAP (FuncReg( 3 TO 4 ), High, X );
     decY : dec2to4 PORT MAP (FuncReg( 5 TO 6 ), High, Y );
     Extern <= I(0) AND T(1);
     Done   <= ((I(0) OR I(1)) AND T(1)) OR ((I(2) OR I(3)) AND T(3));
     Ain    <= (I(2) OR I(3)) AND T(1);
     Gin    <= (I(2) OR I(3)) AND T(2);
     Gout   <= (I(2) OR I(3)) AND T(3);
     AddSub <= I(3);
   RegCntl:
FOR k IN 0 TO 3 GENERATE
  Rin(k) <= ((I(0) OR I(1)) AND T(1) AND X(k)) OR
            ((I(2) OR I(3)) AND T(1) AND X(k));
  Rout(k) <= (I(1) AND T(1) AND Y(k)) OR
             ((I(2) OR I(3)) AND ((T(1) AND X(k)) OR (T(2) AND Y(k))));
END GENERATE RegCntl;
tri_extern : trin PORT MAP (Data, Extern, BusWires );
reg0: regn PORT MAP (BusWires, Rin(0), Clock, R0);
reg1: regn PORT MAP (BusWires, Rin(1), Clock, R1);
reg2: regn PORT MAP (BusWires, Rin(2), Clock, R2);
reg3: regn PORT MAP (BusWires, Rin(3), Clock, R3);
tri0 : trin PORT MAP ( R0, Rout(0), BusWires );
tri1 : trin PORT MAP ( R1, Rout(1), BusWires );
tri2 : trin PORT MAP ( R2, Rout(2), BusWires );
tri3 : trin PORT MAP ( R3, Rout(3), BusWires );
regA : regn PORT MAP (BusWires, Ain, Clock, A );
alu :
WITH AddSub SELECT
    Sum <= A + BusWires WHEN '0',
            A -  BusWires WHEN OTHERS;
regG : regn PORT MAP (Sum, Gin, Clock, G );
triG : trin PORT MAP (G, Gout, BusWires );
END Behaviour;
Test bench in verilog...
module test();
  reg [7:0] Data;
  reg Reset, w;
  reg Clock;
  reg [1:0] F, Rx, Ry;
  wire Done;
  wire [7:0] BusWires;
   task command;
      input [7:0] din;
      input [5:0] cmd;
      begin
         @(posedge Clock);
         @(negedge Clock);
         Data <= din;
         {F, Rx, Ry} <= cmd;
         w <= 1;
         @(negedge Clock);
         w <= 0;
      end
   endtask // command
 proc proc ( Data,
             Reset, w,
             Clock,
             F, Rx, Ry,
             Done,
             BusWires);
   initial begin
      Data = 8'haa;
      Reset = 1;
      w = 0;
      Clock = 0;
      {F, Rx, Ry} = 8'b00_00_00;
      #33 Reset = 0;
      command(0,8'b00_00_00); //ld r0, 00
      wait (Done);
      command(1,8'b00_01_00); //ld r1, 01
      wait (Done);
      command(2,8'b00_10_00); //ld r2, 02
      wait (Done);
      command(3,8'b00_11_00); //ld r3, 03
      wait (Done);
      command(4,8'b01_01_00); //mov r1, r0
      wait (Done);
      command(4,8'b10_00_01); //add r1, r0
      wait (Done);
      command(4,8'b10_01_10); //add r2, r1
      wait (Done);
      command(4,8'b10_10_11); //add r3, r2
      wait (Done);
      command(4,8'b10_11_00); //add r3, r0
      wait (Done);
      #10 $finish;
   end // initial begin
   always #5 Clock = ~Clock;
endmodule // test
hey nand_gates..thanks a lot for showing interest and helping me with my project.
sorry for this but i got this one last problem...i dont quite know verilog the way i know vhdl and hence i really cant totally comprehend the test_bench that u've provided.
if u cud plz suggest any way to convert this code into vhdl or maybe if u dont find it too burdensome (u've really helped me a lot anyway) plz try to provide the vhdl test bench .
but thx anyway, i think like u said the test bench shud work anyway in the simulation but just tht i'd love to have it in vhdl!!!
thx a lot anyway..
cheers
Here I have converted into VHDL but not tested it compiles well..
l
ibrary ieee;
use work.all;
entity test is
end test;
architecture behave of test is
  component proc
  end component;
  signal Data:std_logic_vector(7 downto 0);
  signal Reset, w : std_logic;
  signal Clock: std_logic := '0';
  signal F, Rx, Ry : std_logic_vector(1 downto 0);
  signal Done: std_logic;
  signal BusWires: std_logic_vector(7 downto 0);
begin  -- behave
  Clock <= transport not Clock after 5 ns;
 u1 : proc port map( Data,
                     Reset, w,
                     Clock,
                     F, Rx, Ry,
                     Done,
                     BusWires);
testbench: process
  procedure command (
     din : in std_logic_vector(7 downto 0);
     cmd  : in std_logic_vector(5 downto 0)) is
  begin  -- command
    wait until Clock'event and Clock='1';
    wait until Clock'event and Clock='0';
    Data <= din;
    F    <= cmd(5 downto 4);
    Rx   <= cmd(3 downto 2);
    Ry   <= cmd(1 downto 0);
    w    <= '1';
    w <= '0';
  end command;
begin  -- process testbench
      Data <= "10101010";
      Reset <=  '1';
      w <= '0';
      Clock <= '0';
      F    <= "00";
      Rx   <= "00";
      Ry   <= "00";
      wait for 33 ns;
      Reset <= '0';
      command("00000000","000000"); --ld r0, 00
      wait until Done'event and Done='1';
      command("00000001","000100"); --ld r1, 01
      command("00000010","001000"); --ld r2, 02
      command("00000011","001100"); --ld r3, 03
      command("00000100", "010100"); --mov r1, r0
      command("00000100", "100001"); --add r1, r0
      command("00000100", "100110"); --add r2, r1
      command("00000100", "101011"); --add r3, r2
      command("00000100", "101100"); --add r3, r0
      wait;
end process testbench;
end behave;
Here is the working translated testbench!
Tested OK!
library ieee;
use work.all;
entity test is
end test;
  component proc
  end component;
begin  -- behave
                     Reset, w,
                     Clock,
                     F, Rx, Ry,
                     Done,
                     BusWires);
testbench: process
  procedure command (
  begin  -- command
    Data <= din;
    w    <= '1';
    w <= '0';
  end command;
      Data <= "10101010";
      Reset <=  '1';
      w <= '0';
      F    <= "00";
      Rx   <= "00";
      Ry   <= "00";
      wait for 33 ns;
      Reset <= '0';
      wait until Done='0';
      wait;
end behave;
help this is urgent
thnx for all d help nand_gates.
i'm working on the same project with the_phoenix.we tried your code but we are still geting an error with model sim run.
i'm reposting the entire project as well as the model sim run below. please see if there is anything u can do.
PROC
[library ieee;
use work.all;
entity test is
end test;
component proc
end component;
begin -- behave
Reset, w,
Clock,
F, Rx, Ry,
Done,
BusWires);
testbench: process
procedure command (
begin -- command
Data <= din;
w <= '1';
w <= '0';
end command;
Data <= "10101010";
Reset <= '1';
w <= '0';
F <= "00";
Rx <= "00";
Ry <= "00";
wait for 33 ns;
Reset <= '0';
wait;
end behave;
TEST BENCH
library ieee;
use work.all;
entity test is
end test;
component proc
end component;
begin -- behave
Reset, w,
Clock,
F, Rx, Ry,
Done,
BusWires);
testbench: process
procedure command (
begin -- command
Data <= din;
w <= '1';
w <= '0';
end command;
Data <= "10101010";
Reset <= '1';
w <= '0';
F <= "00";
Rx <= "00";
Ry <= "00";
wait for 33 ns;
Reset <= '0';
wait;
end behave;
DECODER
[library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Uncomment the following lines to use the declarations that are
-- provided for instantiating Xilinx primitive components.
--library UNISIM;
--use UNISIM.VComponents.all;
entity dec2to4 is
En : IN STD_LOGIC;
end dec2to4;
architecture Behavioral of dec2to4 is
SIGNAL Enw : STD_LOGIC_VECTOR(2 DOWNTO 0);
begin
Enw <= En & w;
WITH Enw SELECT
y <= "1000" WHEN "100",
"0100" WHEN "101",
"0010" WHEN "110",
"0001" WHEN "111",
"0000" WHEN OTHERS;
end Behavioral;
REGN
[library IEEE;
--library UNISIM;
entity regn is
Rin : in std_logic;
end regn;
architecture Behavioral of regn is
begin
process
begin
wait until Clock'EVENT AND Clock = '1';
IF Rin = '1' Then
Q <= R;
end if;
end process;
end Behavioral;
TRISTATE BUFFER
[library IEEE;
--library UNISIM;
entity trin is
E : in std_logic;
end trin;
architecture Behavioral of trin is
begin
F <=(OTHERS => 'Z') WHEN E = '0' ELSE X;
end Behavioral;
COUNTER
[library IEEE;
--library UNISIM;
entity upcount is
end upcount;
architecture Behavioral of upcount is
begin
process(clock)
begin
IF (Clock'EVeNT AND Clock = '1') THEN
IF Clear = '1' THEN
Q <= "00";
ELSE
Q <= Q + '1';
END IF;
END IF;
END PROCESS;
end behavioral;
MODEL SIM RUN
[# Reading C:/Modeltech_5.7g/tcl/vsim/pref.tcl
# do test_proj.fdo
# ** Warning: (vlib-34) Library already exists at "work".
# Model Technology ModelSim SE vcom 5.7g Compiler 2003.10 Oct 10 2003
# -- Loading package standard
# -- Loading package std_logic_1164
# -- Compiling package subccts
# -- Loading package std_logic_arith
# -- Loading package std_logic_unsigned
# -- Compiling entity dec2to4
# -- Compiling architecture behavioral of dec2to4
# -- Loading entity dec2to4
# -- Compiling entity regn
# -- Compiling architecture behavioral of regn
# -- Loading entity regn
# -- Compiling entity trin
# -- Compiling architecture behavioral of trin
# -- Loading entity trin
# -- Compiling entity upcount
# -- Compiling architecture behavioral of upcount
# -- Loading entity upcount
# -- Loading package std_logic_signed
# -- Compiling entity proc
# -- Compiling architecture behaviour of proc
# -- Loading entity proc
# -- Compiling entity test
# -- Compiling architecture behave of test
# -- Loading entity test
# vsim -L xilinxcorelib -lib work -t 1ps testbench
# Loading C:/Modeltech_5.7g/win32/../std.standard
# Loading C:/Modeltech_5.7g/win32/../ieee.std_logic_1164(body)
# Loading C:/Modeltech_5.7g/win32/../ieee.numeric_std(body)
# Loading C:/Modeltech_5.7g/win32/../ieee.std_logic_arith(body)
# Loading C:/Modeltech_5.7g/win32/../ieee.std_logic_unsigned(body)
# Loading work.testbench(behavior)
# ** Failure: Default binding had errors for entity "upcount" on the component declaration of line 38. See the compiler messages.
# Time: 0 ps Iteration: 0 Instance: /testbench File: upcnt_tb.vhd
# Fatal error at upcnt_tb.vhd line 45
# while elaborating region: /testbench
# Error loading design
# Error: Error loading design
# Pausing macro execution
# MACRO ./test_proj.fdo PAUSED at line 19
Added after 21 minutes:
i'm sorry i messed that up
i'm adding a text file with all our code please see what u can do.
<<project.vhd>>
library ieee;
use work.all;
ENTITY proc IS
END proc;
  component dec2to4
          En : IN STD_LOGIC;
  end component;
  component regn
           Rin : in std_logic;
  end component;
  component trin
           E : in std_logic;
  end component;
  component  upcount
  end component;
BEGIN
     High <= '1';
     FRin <= w AND T(0);
     AddSub <= I(3);
   RegCntl:
alu :
WITH AddSub SELECT
END Behaviour;
<<subccts.vhd>>
--	Package File Template
--	Purpose: This package defines supplemental types, subtypes,
--		 constants, and functions
library IEEE;
use IEEE.STD_LOGIC_1164.all;
package subccts is
 COMPONENT	REGN
 	generic(n:INTEGER:=8);
	PORT( R:IN std_logic_vector(N-1 downto 0);
			rin,clock:IN STD_LOGIC;
			q: OUT STD_LOGIC_VECToR(N-1 downto 0));
end component;
component trin
	generic(N:integer:=8);
	port(X: IN STD_LOGIC_VECTOR(N-1 downto 0);
			E: In STD_LOGIC;
			F: OUT STD_LOGIC_VECToR (N-1 downto 0));
end component;
component dec2to4
	port(w: In STD_LOGIC_vector (1 downto 0);
			en:IN STD_LOGIC;
			y :out std_logic_vector(0 to 3));
end component;
component upcount
	port(clear,clock:IN STD_LOGIC;
			Q:buffer std_logic_vector(1 downto 0));
end component;
end subccts;
<<dec2to4.vhd>>
library IEEE;
--library UNISIM;
entity dec2to4 is
	 		En : IN STD_LOGIC;
end dec2to4;
begin
	Enw <= En & w;
	WITH Enw SELECT
				"0100" WHEN "101",
				"0010" WHEN "110",
				"0001" WHEN "111",
				"0000" WHEN OTHERS;
end Behavioral;
<<regn.vhd>>
library IEEE;
--library UNISIM;
entity regn is
           Rin : in std_logic;
end regn;
begin
	process
	begin
		IF Rin = '1' Then
			Q <= R;
		end if;
	end process;
end Behavioral;
<<trin.vhd>>
library IEEE;
--library UNISIM;
entity trin is
           E : in std_logic;
end trin;
begin
end Behavioral;
<<upcount.vhd>>
library IEEE;
--library UNISIM;
entity upcount is
end upcount;
begin
	 process(clock)
	 begin
		 	IF Clear = '1' THEN
				Q <= "00";
			ELSE
				Q <= Q + '1';
				END IF;
			END IF;
		END PROCESS;
end behavioral;
<<test_proc.vhd>>
library ieee;
use work.all;
entity test is
end test;
  component proc
  end component;
begin  -- behave
                     Reset, w,
                     Clock,
                     F, Rx, Ry,
                     Done,
                     BusWires);
testbench: process
  procedure command (
  begin  -- command
    Data <= din;
    w    <= '1';
    w <= '0';
  end command;
      Data <= "10101010";
      Reset <=  '1';
      w <= '0';
      F    <= "00";
      Rx   <= "00";
      Ry   <= "00";
      wait for 33 ns;
      Reset <= '0';
      wait;
end behave;
AND FINALLY THE MODEL SIM RUN
# do test_proj.fdo
I dont know what you have in ur do file.
Do run modelsim with following do file!
vlib work
vcom dec2to4.vhd regn.vhd upcount.vhd trin.vhd proc.vhd test.vhd
vsim test
add wave -r /*
run 400
hey...nand_gates ...i cdunt quite come up with enough words to thnk u ...
everything seems to run just fine in modelsim timing simulation...
tho' i still have one last query...wht does the code addon mean...(the one in ur last post) and can we tweak the Test bench so tht this can be taken care of and the simulation can run unhindered??
thx anyway
About "add r1 r2 " comments.
Its just a comment just ignore it i have tried to guess what the code is doing!!
i'm sorry i was referring to the foll code
vlib work
vsim test
add wave -r /*
run 400
Here add wave -r /* adds all signals in design reccurcively to the waveform viewer!
its a standerd modeltech command!
