No more 455Khz IF transformers ? Is analog Superhet obsolete..
kripacharya
Banned
New Delhi
I went looking for specs & sources of those IFT cans which were used in superhet receivers, and found almost nothing.
Has everything gone digital ? Or am I looking in the wrong places ?
My application is somewhat different. It is to implement a double-tuned BPF, with voltage gain as well.
What I need is a small (signal) transformer with a high-ish ratio of around 1:30 or more if possible. It would work in the region of 100Khz to 400Khz. The larger coil would be in the region of around 0.5mH. And it needs to be tuneable !
And lastly - as stable as feasible/ practical. Less than 200ppm/ deg C?
Well they are still available on eBay as hobbyist items. Some even sold as complete set for making a superhet radio (Red = OSC, Yellow=1st IF, White=2nd IF, Black=3rd IF).
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.X455KHz+IF+transformer.TRS0&_nkw=455KHz+IF+transformer&_sacat=0
I still have a few 6-transistors AM/FM radios where there are some of these IFT to be used as parts. No sure if the cheap Chinese multi-band radios use IFT or ceramic resonators.
Allen
there are a few superhet receiver chips that still work with a 10.7 MHz if. switch to that frequency plan.
Thanks, but I am not looking to build a radio. It's for a different application.
Yes they are pretty much obsolete unless you need mass production qty.
Everything has pretty much gone to ceramic resonators
455Khz with 150 pc min order here :cool:
Any pointers on who could make such a trafo, if the mass qty requirement was there ?
