[SOLVED] No clock signal at sck pin in spi communication
Pushpkant
India
I am trying to send data from one atmega8 to another atmega8 using the spi.
But on the master mpu there is no clock signal at sck pin.
Check in software, SPI initialisation , clock setting and other stuffs.
I am using the following code:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
// SPI master to send data to another MCU
#include<avr/io.h>
#define DDR_SPI DDRB
#define DD_MOSI PB3
#define DD_SCK  PB5
#define DD_SS   PB2
void SPI_MasterInit(void)
    /* Set MOSI and SCK output and SS as output, all other input */
    DDR_SPI = ( 1 << DD_MOSI) | ( 1 << DD_SCK) | ( 1 << DD_SS);
    /* Enable SPI, Master, set clock rate */
    SPCR = ( 1 << SPE) | ( 1 << MSTR) | (1 << SPR0) | (1 << SPR1);
    return;
void SPI_MasterTransmit(char cData)
    /* Start Transmission */
    SPDR = cData;
    /* Wait for transmission to complete */
    while(~(SPSR & (1 << SPIF)))
    return;
void msdelay(unsigned long itime)
    unsigned long i,j;
    for(i=0; i< itime; i++)
        for(j=0; j<1000; j++)
    return;
int main()
    unsigned int i;
    i=0;
    DDRC = 0xFF;
    DDRD = 0xFF;
    SPI_MasterInit();
    while(1)
        SPI_MasterTransmit(i);
        PORTD = i;
        msdelay(1);
        i++;
    return 0;
I don't know why the previous code is not running. But this one is OK,
I am getting the clock signal now at SCK Pin.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
// SPI_test 2
#include<avr/io.h>
void SPI_Init(void)
    DDRB |= (1<<2) | (1<<3) | (1<<5);   //SCK, MOSI and SS as output
    DDRB &= ~(1<<4);                    //MISO as input
    SPCR |= (1 << MSTR);                //set as master
    SPCR |= (1 << SPR0) | (1 << SPR1);  //set spi clock as fck/128
    SPCR |= (1 << SPE);                 // enable the spi
    return;
void SPI_Master_Tx(unsigned char data)
    SPDR = data;
    while(!(SPSR & (1<<SPIF)))
    return;
    unsigned long i,j;
    for(i=0; i<itime; i++)
        for(j=0;j<1000; j++)
    return;
int main()
    unsigned char i=0;
    DDRC = 0xFF;
    SPI_Init();
    while(1)
        SPI_Master_Tx(i);
        PORTC = 0x55;
        msdelay(10);
        PORTC = 0xAA;
        msdelay(10);
    return 0;
