NIOS II Custom Instruction blocks printf
kalyansrinivas
Hi
I am trying to add custom Instruction block to my SOPC Builder Design but i find the printf gets blocked whenever i add custom instruction to my design .I even powered off and powered on by board but still i see that the Printf doesnt print on the console
Please help me out
regards
M Kalyansrinivas
Go to QuartusII project directory and then, delet db and incremental db directory from that and recompile your Qurtus project. Then try, printf will be there on console of NIOSII IDE.
HTH
Shitansh Vaghela
Hi Shitansh Vaghela
Thank you for the reply and i will try it out
but one doubt that
if i recomplile the quartus project i found that db and incremental db folders are again getting created
so please tell me whether after deleting db and incremental db folders do i need to re-synthesis
quartus project or shall i just run nios -ide compiler
Thank you vey much for the reply
regards
M Kalyansrinivas
HI,
Say you are getting problem in printf now every thing else if working fine in NIOSII IDE (say i = j+k;) then you may need to resynthesis and compile your quartus project, before recompile and resynthesis you need to delet db and incremental db folder form your quartus project directry and after new compilation and synthesis db and incremental db will agin created you need not to delet at this time untill you want to resynthesis and compile again.
HTH
Shitansh Vaghela
Hi Shitansh Vaghela
I did the same but i could not end up with printf printing on the console ,
but before to that i see the following error in the Sopc Generator when i try to add custom instruction to my design
Error : slave(cpu_adder_inst/avalon_slave) data width is 0
Error : Generator program for module 'cpu' did not run successfully
But even i have this error SOPC generates the ptf file and i am able to proceed to genarating the sof file
Please help me out of this problem
regards
M Kalyansrinivas
hi,
you need not to have regenerate sopc. only need to full complie design as describe before.
Shitansh Vaghela
As per your mail and error i conceived that u have selected burst mode , in this case u have to mention the min datawidth =1. Actually assertions are inbuilt in IPs. May be they exiting the simulation if condition is voilated i.e. datawidth =0
Better change to datawidth =1 and try once.
Regards,
ravi
