Nice I2C asembler routine for PIC16F84A needed
traxonja
i2c pic16f84
Hello,
does anybody have a nice (clean) routine for writing and reading-from an I2C memory device written for MPASM?
I will use PIC16F84A, and 24LC16 (2k) device so 1-byte address will be used, but 2-byte addresses are OK too.
I have this attached routine but it doesn't work :( , so if you have a nice tested one please post it here.
When I programm the device in PicBasic, it works, but with this routine in MPASM it doesn't work :(
All best,
Trax
zmanultra
Member level 2
Australia
pic16f84a i2c
Hi
is what the device that u have a smartcard (gold wafer) caus that cojntains the 2 ICs u talking about.
traxonja
i2c pic16f84a
No, it's only my PIC and some eeprom, in my case it is 24c16.
Trax
Kripton2035
Western Europe
i2c assembler
be aware that if you look at the details of the picbasic language, the i2c routines works well only with hard i2c chips for example 16f876, but not the 16f84...
they work quite in master mode, but quite not in slave.
sam_manchali
Member level 4
sharjah
16f i2c
hi,
check out the routines provided by microchip itself, they work fine to my knowleded!!
cheers
sam
traxonja
pic16f84a+24c01
Thanks for the answers. I found a nice routine at www.piclist.com.
And, I couldn't download a file from this forum because I am stil a new user and I don't have any points :( :)
Best regards,
Trax
elektryk
POLAND
pic16f84 i2c
You have now ;)
mbyka
Full Member level 5
from istanbul in TURKEY
pic16f84 magnetic card reader
Hi
I can help you with my sample code
maybe :)
LIST P=16F84
	INCLUDE "P16F84.inc"
	TITLE " 24Cxx Programming with pic"
EEPROM	EQU 1CH
ADDR		EQU 1DH
DATAI		EQU 1EH
DATAO		EQU 1FH
TXBUF		EQU 20H
RXBUF		EQU 21H
COUNT		EQU 22H
DEL		EQU 23H
SEL 		EQU 24H
DI		EQU 7
DO		EQU 6
SDA		EQU 1
SCL		EQU 0
;PortA.0--------->Serial Clock----------24Cxx's Pin:6
;PortA.1<-------->Serial Data-----------24Cxx's Pin:5
;PortB LED outs
	__CONFIG _WDT_OFF & _XT_OSC & _CP_OFF
;========= start======================
	ORG 000H
	GOTO START
START
	CALL PORT_INIT
MAIN
	MOVLW 00H			;Eeprom write Adress
	MOVWF ADDR
	MOVLW 23H			;Eeprom  data
	MOVWF DATAO
	CALL WRITE_EEPROM
	MOVLW .100
	CALL DELAY_NMS
	MOVLW 00H			;Eeprom read adress
	MOVWF ADDR
	CALL READ_EEPROM
	MOVF DATAI,W
	MOVWF PORTB			;read from Eeprom transfer data portb
	MOVLW .100
	CALL DELAY_NMS
DONE
	GOTO DONE
;================= Port Init ============================
PORT_INIT
	CLRF PORTA
	CLRF PORTB
	BSF STATUS, RP0		;page1 select
	CLRF TRISA
	CLRF TRISB
	BCF STATUS, RP0		;page0 select
	CLRF PORTB
	RETURN
;======== eeprom cominication=========================
WRITE_EEPROM
	CALL BSTART
	MOVLW B'10100000'
	MOVWF TXBUF
	CALL TX
	MOVF ADDR,W
	MOVWF TXBUF
	CALL TX
	MOVF DATAO,W
	MOVWF TXBUF
	CALL TX
	CALL BSTOP
	RETURN
READ_EEPROM
	CALL BSTART
	MOVLW B'10100000'
	MOVWF TXBUF
	CALL TX
	MOVF ADDR,W
	MOVWF TXBUF
	CALL TX
	CALL BSTART
	MOVLW B'10100001'
	MOVWF TXBUF
	CALL TX
	CALL RX
	CALL BSTOP
	RETURN
BSTART
	BSF PORTA,SDA
	BSF STATUS, RP0
	MOVLW 00H
	MOVWF TRISA
	BCF STATUS, RP0
	BCF PORTA,SCL
	NOP
	BSF PORTA,SCL
	NOP
	NOP
	NOP
	NOP
	NOP
	BCF PORTA,SDA
	NOP
	NOP
	NOP
	NOP
	NOP
	BCF PORTA,SCL
	NOP
	NOP
	RETURN
BSTOP
	BSF STATUS, RP0
	MOVLW 00H
	MOVWF TRISA
	BCF STATUS, RP0
	BCF PORTA,SDA
	NOP
	NOP
	NOP
	BSF PORTA,SCL
	NOP
	NOP
	NOP
	BSF PORTA,SDA
	NOP
	NOP
	BCF PORTA,SCL
	NOP
	NOP
	NOP
	RETURN
BITOUT
	BSF STATUS, RP0
	MOVLW 00H
	MOVWF TRISA
	BCF STATUS, RP0
	BTFSS EEPROM,DO
	GOTO BITLOW
	BSF PORTA,SDA
	GOTO CLK_OUT
BITLOW
	BCF PORTA,SDA
CLK_OUT
	BSF PORTA,SCL
	NOP
	NOP
	NOP
	NOP
	BCF PORTA,SCL
	NOP
	RETURN
BITIN
	BSF EEPROM,DI
	BSF STATUS,RP0
	MOVLW 02H
	MOVWF TRISA
	BCF STATUS, RP0
	BSF PORTA,SCL
	NOP
	NOP
	NOP
	NOP
	NOP
	BTFSS PORTA,SDA
	BCF EEPROM,DI
	BCF PORTA,SCL
	RETURN
TX
	MOVLW .8
	MOVWF COUNT
TXLP
	BCF EEPROM,DO
	BTFSC TXBUF,7
	BSF EEPROM,DO
	CALL BITOUT
	RLF TXBUF,F
	DECFSZ COUNT,F
	GOTO TXLP
	CALL BITIN
	RETURN
RX
	CLRF DATAI
	MOVLW .8
	MOVWF COUNT
	BCF STATUS,0
RXLP
	RLF DATAI,F
	CALL BITIN
	BTFSC EEPROM,DI
	BSF DATAI,0
	DECFSZ COUNT,F
	GOTO RXLP
	BSF EEPROM,DO
	CALL BITOUT
	RETURN
DELAY_NMS
	MOVWF DEL
OUTTER_MS
	MOVLW .110
	MOVWF SEL
INNER_MS
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	DECFSZ SEL,F
	GOTO INNER_MS
	DECFSZ DEL,F
	GOTO OUTTER_MS
	RETURN
END
elcielo
Full Member level 6
hassan1980
Full Member level 4
tsa5055 pic
I want a clear program for just reading and writing in serial eeprom like 24C64 with 16f84.
I need your help
dragosdiaconita
Newbie level 1
pic16f84 i2c slave basic
does anyone have an exe file to comunicate with the 16f84 serial out?
pls?
ty for ure kindnes
tonybg
Junior Member level 3
bulgaria
pic16f84 read 24c01 eeprom
Why don't you try Application Maestro.It's a part of MPLAB.Generates many protocols,and explains all the details about hardware and software on the specfic code it generates.Hope it helped:D
iman_andeh
Newbie level 6
i2c pic16f
how to communicate (read and write) the gold wafer card using other PIC mcu such as PIC16F877A?
i'm trying to build a portable gold wafer card reader/writer...
zmanultra
Member level 2
Australia
i2c with pic16f84a
its like programming a normal pic processor....the only difference is that u must creat a serial Comm routine...check out picbasic pro...it has some serial routines...thats the easiest way....or u can use microchip compiler....
hope this helps
iman_andeh
Newbie level 6
16f84+i2c
is there any sample code that used to write gold wafer card?
zmanultra
Member level 2
Australia
master i2c for pic16f690
dont worry about "gold wafer card" look at it as simply programming a chip....(pic16) have u programed that chip b4....if not, just have a look at the sample code provided (e.g. pic basic is good for beginers)
iman_andeh
Newbie level 6
pic16f84a mit i²c
yes, i have programmed PIC before, that is PIC16F877a..
about gold wafer card,
i'm really confused what i should do now.
i tend to use circuit below as my gold wafer card reader and programmer
this circuit was grabbed from Silicon Chip (issue 178 (July 15, 2003), by Peter Smith)
but,
i really have no idea about the code. could you give an example code?
