Newbie question for Protel Autotrax 1.61 users
Trevor
Newbie level 5
Hi All
Sorry if this is a really dumb question. There's probably some obvious answer that I can't see.
In Autotrax 1.61, when placing an IC library component such as a DIP14, the rectangular pad indicating pin 1 appears to be on the wrong side. In other words, if I'm looking "through" the board from the solder side at an IC with its semi-circular noth uppermost, the pin 1 pad is on the left and not on the right which is where is should be. Can anyone tell me what I'm missing?
Thanks in advance.
Trevor
amjad
Full Member level 5
You need to mirror the component while placing, if you are viewing from bottom side of the component.
Trevor
Newbie level 5
Amjad
Thanks for the reply. Sorry to ask another dumb question but how do I "mirror" a component with AutoTrax? I know how to rotate but not how you mirror.
Regards
Trevor
