6 digit 7 segment
Code sample from ET-JRAVR V1.0 + SDP8 ( **broken link removed** )
;* APPLICATION NOTE FOR THE CP-JRAVR *
;* Control Board :CP-JRAVR *
;* File Name :"SDP8.ASM" *
;* Title :7 SEGMENT DISPLA *
;* Date :10/9/42 *
;* Version :1.0 *
;* Target MCU :AT90S2313/AT90LS2313 *
.include "2313def.inc"
.ORG $0000
RJMP RESET_VEC ;Reset Handle
.EQU PORT_MAX = PORTB
.EQU DDR_MAX = DDRB
.EQU BIT_LOAD = 5
.EQU BIT_DIN = 6
.EQU BIT_CLK = 7
.DEF TEMP = R19
.DEF TEMP1 = R20
.DEF TEMP2 = R21
.DEF TEMP3 = R22
RESET_VEC: LDI TEMP,LOW(RAMEND)
OUT SPL,TEMP ;init Stack Pointer Low
LDI TEMP,HIGH(RAMEND)
OUT SPL+1,TEMP ;init Stack Pointer High
RCALL DELAY ;delay for start
SBI DDR_MAX,BIT_LOAD
SBI DDR_MAX,BIT_DIN
SBI DDR_MAX,BIT_CLK
SBI PORT_MAX,BIT_LOAD
SBI PORT_MAX,BIT_DIN
CBI PORT_MAX,BIT_CLK
RCALL INIT_7219
LDI TEMP3,0X01
LDI TEMP2,0X00
RCALL MAX7219
LDI TEMP3,0X02
LDI TEMP2,0X01
RCALL MAX7219
LDI TEMP3,0X03
LDI TEMP2,0X02
RCALL MAX7219
LDI TEMP3,0X04
LDI TEMP2,0X03
RCALL MAX7219
LDI TEMP3,0X05
LDI TEMP2,0X04
RCALL MAX7219
LDI TEMP3,0X06
LDI TEMP2,0X05
RCALL MAX7219
LDI TEMP3,0X07
LDI TEMP2,0X06
RCALL MAX7219
LDI TEMP3,0X08
LDI TEMP2,0X07
RCALL MAX7219
WAIT: RJMP WAIT
;* initial MAX7219 *
INIT_7219: LDI TEMP3,0X09 ;decode address
LDI TEMP2,0XFF ;decode digit 7-0
RCALL MAX7219
LDI TEMP3,0X0A
LDI TEMP2,0X0F
RCALL MAX7219
LDI TEMP3,0X0B ;scan address
LDI TEMP2,0X07 ;scan 8 digit
RCALL MAX7219
LDI TEMP3,0X0C ;short down mode
LDI TEMP2,0X01 ;normal operate
RCALL MAX7219
LDI TEMP3,0X0F
LDI TEMP2,0X00
RCALL MAX7219
RET
MAX7219: CBI PORT_MAX,BIT_LOAD
LDI TEMP1,16
SDP1: CBI PORT_MAX,BIT_DIN
LSL TEMP2
ROL TEMP3
BRCC SDP2
SDP2: CBI PORT_MAX,BIT_CLK
SBI PORT_MAX,BIT_CLK
DEC TEMP1
BRNE SDP1
RET
;* DELAY TIME FOR START *
DELAY: PUSH R26
PUSH R27
LDI R27,0XFF
DEL2: LDI R26,0XFF
DEL1: DEC R26
BRNE DEL1
DEC R27
BRNE DEL2
POP R27
POP R26
RET
