New to FPGA's, couple of questions
jbs87
Newbie level 6
Newbie level 6
Hi all
I'm interested in learning how to program FPGA's and have a couple of questions:
)What is a good book for self study. I have a book by Samir Palnitkar? It seems to be about Verilog but do i need a book with regards to specific implementation on FPGA's?
)Where can I find some decent projects to test out my skills once I've covered the material a fair bit. It would be great if they had some sort of tips to help me along. I forgot to mention I have a Core MP7duo board which I got free from a vendor. Is it any good?
Hello,
1. Choose FPGA - Xilinx or @ltera are my recommendations
2. Read the datasheet
3. Download the software web pack, either ISE or Quartus II
4. Then read a tutorial on the software - Google is your friend :-)
5. Write the code - verilog or vhdl - also you can try schematic capture.
6. If you have a development board you can try your code and surely there is code on the net for your development board. If you have a custom board, then you are on your own, but you can try most code out there.
Opencores.org is a good free and open source of code site.
Got some quick tutorial here for xilinx. U must have at least the xilinx webpack. Hope this helps
this one is good --
Design Warrior's Guide to FPGAs, Clive Maxfield
ram
I recommend you to start a design and in parallel read books and datasheet! it will boost your learning.
If conditions allows, you can first do some experiments on fpga evalu board. quickly make sense of how fpga implemention.
BR.
ls000rhb
LaTeX Commands Quick-Menu:
