[SOLVED] New to eagle..small question
Darkcrusher
Member level 5
Belgium
Hi how can I substract the rectangle from the loop in eagle layout? (see picture)
I give away points for good reply.. :)
Darkcrusher
Member level 5
Belgium
it is a layout, I want to draw a pcb disc coil with a gap. But there is a problem, eagle draws the 360 degree full circle. I want the 359.99 degree one: a split ring:
53044d1296733179-currents-gif
Darkcrusher
Member level 5
Belgium
Seems reasonable, but thats the prob... I dont like the arc in eagle, the ends are rounded...
Darkcrusher
Member level 5
Belgium
I dont know what you mean but I found that this helped:
"change"->"Cap"->"Flat"
Thank you for your time.
Cheers
keith1200rs
Super Moderator
Staff member
Yorkshire, UK
When you select "arc", at the top of the screen you should see icons for layer, width, rotation direction and two others. They select the straight or rounded end.
I have never used "arc cap" but looking it up, it is just doing the same thing from the command line.
Keith.
Darkcrusher
Member level 5
Belgium
I did not notice the parameter toolbar since it apparently was turned off. Thx again :)
cheers
