New kit announcement, Junebug (PICKit2 SE & Firefly)
blueroomelectronics
Advanced Member level 5
Toronto, Canada
pickit2 se
Just putting the prototype through the paces and always enjoy the comments.
The PICKit 2 from Microchip is fast becoming an excellent choice for anyone starting with PICs. Although a genuine PICKit 2 is only $38 (digikey) so building a clone would not be very profitable (there is ebay PK2 clone from China for $10 but the shipping is $20 and you still need the USB cable)
So here's what we're doing at blueroomelectronics.
Junebug is a combination PK2 SE (Student edition 5V only VDD, a genuine PK2 supports 3.3V PICs) and an updated Firefly kit **broken link removed**
On a single small 115mm x 57mm PCB. The image below will be updated as the design is being drawn. It will also be BLUE :D
The Firefly schematic can be found on our site, but here's the PK2 schematic.
And yes it works great with both MPLAB and PICKit2 software.
Here's the hand wired prototype, (early version, works fine)
pk2v021000.hex
It's coming along nicely, you'll have to refresh your browser to see the board (should be blue) in the first post.
Notice it's also a new size 115mm x 57mm, compatable with the LAB-EASY prototyping system (I'll post a photo, I'm sure most will want one)
The dipswitch IMHO is better than using jumpers as you can't lose them!
Here's what it does.
1. VR2, connects potentiometer2 to 16F88
2. VR1, connects potentiometer1 to 16F88
3. IRIN, connects IR receiver to PIC
4. TX, connects 16F88 UART to PICKit 2 UART test (very cool feature)
5. RX, connects 16F88 UART to PICKit 2 UART test *
6. I2P, connects 24LC64 EEPROM to PICKit 2 EEPROM programmer**
7. I2T, connects 24LC64 to 16F88 SSP (only a partial master)**
8. Tutor, connects 16F88 to PICKit 2
* uses PK2 software, does not work while debugging
** it should be possible to set the 16F88 up as an EEPROM emulator
pk2v021000
Would you please Uplaod the the hex file and the exe program?
pickit2 eeprom
If you mean the firmware for the PK2 it can be downloaded free from Microchip.
The file you want is PK2V021000.hex
I used a 18F4550 in the prototype it's what I hand on hand. The 18F2550 is 28pin
Added after 1 hours 20 minutes:
Here's an almost complete 3D image of the Junebug PIC Lab.
The tutor is for a 18F1320 PIC
download pickit2 2.5
The double row of socket pins are for either a 16F88 or 18F1320 PIC
dearfriend I appreciate your reply
I have a question :
At the first picture you post you use 18F2550
then at the second picture I saw that 18F4550 is used
would you please explaine more?
pickit2 2.5
The 18F4550 and the 18F2550 have the same core, the only difference are the addition PORT D & E. I had a 18F4550 on hand so used that, it works fine.
junebug (pickit2 compatible)
Mr. blueroomelectronics
If I used the schematic you post at the beginning and the hex file you mentioned I will got PICKIT2
is this correct or not?
I mean this schematic
pickit2 16f88
That schematic is correct for the PICkit 2 part of Junebug. It's correct for the 18F2550. If you use a 18F4550 you must rewire the pins based on their functions.
junebug ferrite bead
Ok, dearfriend
would you please uplaod the source for the schematic because it has low quality
All replies are appreciated
firefly pcb download
I'll be posting a complete version on my site in the next couple of days. That'll be the best place to find it.
If you just want to build a PICkit 2 the full schematic is in the user manual.
irlm6402
The design is near completion the EEPROM has been removed in favor of a PK2 connector and EUSART + MSSP I/O connector.
So you can use the kit as a USB experimenter like this fellow.
using pickit 2 uart too
Dearfriend, I am still waiting to uplaod this schematic in high reselution I suggest to upload it as PDF or to put the source
pic kit 2 pakistan
If you want something now then just download the PICkit 2 manual from Microchip, the full schematic is there and in high resolution too.
junebug usb kit review
Hi blueroomelectronics
I see that you have not the two I2C memories.
Do you put in another sheet?
is it for the PID?
Thanks.
junebug pk2
The I2C EEPROMs are currently not used in the PICkit2, there is always a chance they may use them in the future so I've made the pins available on the extended PK2 compatible header on the top.
Seems a few people use their PK2 as a USB test platform. There will be ICD pins under the 18F2550 for reprogramming if needed.
usart pic kit 2
Nice work blueroomelectronics.
I also like the PICkit 2, I made a simple clone (only VDD) some time ago to program the 10F222, because I had problems with my ICD2 clone.
I already solved the problem of my ICD2 clone, and I'm using almost daily a original ICD2, but I like a lot the PICkit 2 ;-)
junebug pic schema
The PCB Artwork has been completed and the boards should be ready next week. Here's the Junebug mounted in a LAB-EASY prototyping kit. More images to follow.
Added after 5 hours 32 minutes:
And here's the BT-06L with optional breadboard installed. But the best part is yet to come.
junebug pic firmware
What software have you used to do the PCB artwork?
It's really great! Congratulations for your entire job.
Rodrigo
pickit2 free shipping
Thanks, it's a program called SketchUp. And there's even a free version of it.
Here's the LAB-EASY secret, the thin 1mm PCBs can be assembled while mounted on the breadboard. Once you get it working you can solder it down and remove from the breadboard. The PCBs can also be cut with scissors. Amazing!
pk2v021000+bl.hex
Hi
Good work. But I don’t understand some things about solder down.
I think, if I finish my prototype and then I want solder down, how I can do this if the breadboard keep hold the wires and I suppose can not rotate only the PCB.
