Register Log in
New High Voltage SiC diodes are not marking the end of BCM Boost PFC controllers?
treez
Advanced Member level 5
cambridge
Why haven’t new high voltage SiC diodes meant large reductions in the sales of BCM Boost PFC control chips? After all, the main advantage of the BCM Boost PFC is its lack of reverse recovery problems. But new SiC diodes massively reduce such problems when Boost PFC’s are done in CCM.
A CCM Boost PFC doesn’t need an extra winding in the Boost inductor, which the BCM Boost PFC needs.
dick_freebird
USA
Design-in cycle = ???
Production release cycle = ???
Desirability of a 4V Vf = "not very".
Reactions: treez
    treez
Easy peasy
Melbourne
20 & 38A max forward current, respectively, for half sine wave surge rating is a limiting factor for those diodes - if you turn off and then on it can go bang due to inrush - compare to Si diodes ...
Reactions: treez
    treez
treez
cambridge
Thanks, i see your point, it makes you wonder why SiC diodes are used in CCM PFCs at all.
I even went to an interview at a quite big electronics company making medical stuff and the guy's question was..."tell me about the SiC diodes that you would use in a CCM Boost PFC"
I can see that there would need to be a circuit to do "OFF then ON again" sensing...probably this would be easiest using a microcontroller.
Though surely you could short out the SiC diodes to inrush with a regular Si diode connected from Boost input to Output?...
dick_freebird
USA
I'm sure a SiC diode could be made with a higher Ipk/Isteady
margin. But it's not as easy when you operate at >3X the Vf
(so power density 3X) and crowd the heat into a smaller
region as well (more of it shed at the junction, less in the
drift region / bulk). They'd probably have to work at it and
there's about 50 years' less product differentiation been
done, yet.
If you "short" the SiC diode with a silicon rectifier, have
you not just made the SiC device irrelevant?
Reactions: treez
    treez
treez
cambridge
Well, i mean like in the boost PFCs where you get the diode connected from input to output, and its just always reverse biased when the boost gets powered up.
treez
cambridge
With this "bypass" diode, there wouldnt be significant inrush in the boost diode
treez
cambridge
So since the Boost PFC diode will never see inrush (when inrush is bypassed as discussed), then why are BCM Boost PFC controllers so popular?
I mean, BCM Boost PFCs need an extra winding in the Boost inductor….why bother with this faff when you can just do CCM Boost PFC instead? Another point is that BCM Boost PFC’s suffer from very high frequency operation when on light load…this results in unnecessarily high switching losses, since BCM Boost PFC’s do nothing to help turn-OFF switching losses….
Also, when the load lightens, BCM Boost PFCs get more noisy and loose PFC operation quicker than CCM PFC’s…this is because the signal from the “signal” winding on the BCM Boost inductor gets very oscillatory and so the zero crossing point is often not distinct enough to be picked out by the ZCD comparator.
All this is a big downer for BCM Boost PFC.
So why do it?..why not CCM Boost PFC instead?
Easy peasy
Melbourne
Actually BCM boosters can be made very quiet - and use std Si diodes optimised for low on drop ( Trr = 50/75nS ) due to the low volt turn on of the fet ( diode already largely biased off) the main drawback is the ripple current in the caps feeding the power ckt - we have made dual interleaved BCM boosters to 1.5kW and they work straight off the bat ( 180 - 265 Vac )
One needs to keep the max freq to reasonable bounds, and ensure current balance in the 2 // stages -
Reactions: treez
    treez
treez
cambridge
Easy peasy
Melbourne
You need to understand all the aspects of DCM or BCM boost ...
Reactions: treez
    treez
Toggle Sidebar
