monty_burns_007
Member level 2
- Joined
- Jun 4, 2001
- Messages
- 46
- Helped
- 5
- Reputation
- 10
- Reaction score
- 4
- Trophy points
- 1,288
- Location
- Springfield
- Activity points
- 448
soft applicom
Ethernet TCP/IP protocols (can be used at the same time):
Alstom SRTP (Alspa C80-35 and C80-75)
Siemens Industrial Ethernet TCP/IP (S5, S7, TI),
Schneider Uni-TE on TCP/IP (TSX/PMX),
Open Modbus TCP/IP,
Omron FINS TCP/IP (Seris C, CS, CV)
Mitsubishi Melsec (series A & Q)
GE Fanuc SRTP (series 90-30, 90-70)
Serial protocols:
AS511 Master (Siemens S5 PLC prog. port)
Modbus Master (ASCII, RTU)
Modbus Slave (ASCII, RTU)
SNP -X Master (GE-Fanuc PLC)
TI-Dir Master (prog. port for Siemens Texas Instrument PLC)
Uni-Telway : Slave Client/Server (Schneider Telemecanique PLC)
PPI master (progr. port for Siemens S7 -200 PLC)
http://www.applicom-int.com/files/trial/SW_ETH.EXE
this is the full version, you only need a code to make it full, otherwise it runs completely as full for 30 mins.
Monty 8)
Open Modbus TCP/IP,
Serial protocols:
Monty 8)
