network simulation using opnet
free network simulator
hi,
u can use
ns2
glomosim...but a problem wth this s u hav 2 draw outputs manually...graph like items...using matlab
implementing using matlab...but 4 large scale simulation , not useful..
it depends on ur work...
mention the work
bye
network simulator 14.0.a
Follow this link:
register with user name/password and you will be able to download the free academic version immediately.
network simulator free download ns2 windows
Can anybodu upload opnet IT Guru???
opnet free download-acdemic version
Hi everybody on the topic.
Here i am also in trouble.I need to create a linux based network simulator.
plz give some help.
download free network simulator ns2
plz give some help.
what do you mean "create"? you wanna design a new network simulator on linux? em, sounds great, but too hard...
or you just want to run a simulator on linux? if so, you can try the ns2, it's free and easily to install on linux.
install opnet xp
yes i have to design one n/w simulator.......
PLZ advice
step by step guide setting up network simulator
aha, so if you are a LInux user, i would suggest the ns-2 ( during my researches i found out that it is the most used one )
good luck
Added after 2 minutes:
you can check :
for more info concerning the ns-2
opnet simulator for windows
plz help in designing a network simulator on linux.will ns-2 help?????
Can it be modified as per my requirements???????
download free simulation + unix
Hi, this is step by step tutorial to install cygwin + ns-2 on Windows Xp
ns2 simulator free downloads
use omnet++. also the lan trainer kit in few of the internet labs.
opnet network simulator
Really There a lot of Simulation
But the most Powerful Simulation for CISCO is BOSON here is the link for CCNA and CCNP Simulation
free ieee download ns2 projects
U can use network simulator (ns) .. in Linux
opnet simulation free download
I have good network simulation
but shareware, if you want contac me
opnet simulator + free download
If you searching for the GSM and CDMA network then there are many help file in the matlab help folder. Go and try. Best of luck
ns2 simulator free download for windows
net visulizer 5
It is helpful for CCNA Exams
free opnet network simulator
NR - Network Recorder
NR enables you to record and view screenshots of the activities of other users in your local network. You can see what any user did any day/hour, you can browse through the screens using sophisticated user-interface and search tools. You can even set alerts on specific words or actions.
NR uses the vLog's patent-pending recording engine so it does not utilize too much CPU and disk-space. The user in the recorded client doesn't feel it.
It is also secured so no one (but you) can view the recordings.
Who will use NR?
Companies that want to prevent data leakage or emplyees' misconduct.
Companies that want to analyze their staff applications' activities.
IT Managers to analyze problems in the servers.
Call-Centers managers to supervise and analyze the CSR's work.
Key Features:
NR utilizes minimal CPU and disk space.
NR can be set to be hidden in the client's computer.
NR can be set to record only specific applications or URLs.
NR records text and has advanced Search and Alert utilities.
The recorded data is encrypted and can be viewed only by the Viewer.
Other Viewers can view the data if approved by the main Viewer.
NR can record even when the user's computer is disconnected.
NR has an Auto Cleanup and a Backup utilities.
NR is designed to work with one or many clients.
NR has a comprehensive usage table and network usage reports.
The answer to your question is as follows:
if you are working in the physical layer : MATLAB is the best
if you are working on the upper layers: OMNET, QUALNET or OPNET are prefered
