netlist transfer issue 。。。
jayh
Newbie level 6
canada
now i met a issue about netlist transfer.
a netlist based on A std lib. the owner doesn't provide source code for security issue. and we want to transfer the netlist to another one based on B std lib. or from ASIC to FPGA......
is it feasible to do such netlist transfer? by any tool and any flow?
do u have any suggestion? thank you!
It should not be difficult. If you don't have lib A available to you, write the behavior model for each of the lib A cells used in the design, and then the design will become "gate-level RTL". Synthesis it to lib B.
I think you can specify both lib A and lib B in link library and specify target library as lib B...in Design Compiler...once check and let me know
