Active bias wants that negative voltage controlled,
to get a chosen drain current setpoint. The -6V is
probably the supply rail and pinchoff of the FETs /
HEMTs probably about -3V, to be set by a feedback
amplifier (or cal-mapped DAC, or ...).
I have no good idea of the amplifier particulars to
say whether the negative voltage pin is the supply
(with active bias amp on chip) or the control point
(bias gate network brought out, bare).
The problem with a close-in inverter switcher is that
it's going to throw switching noise onto the bias gate
network unless you are really careful with filtering.
Spurs at 100K - 1MHz offset will really mess up your
frequency mask compliance.
The gate network wants a low impedance to keep
noise down (forget which kind, but that's what the
microwave module guys I designed element control
chips for, told me).
If you use a voltage inverter DC-DC then you will
want to give it enough headroom to put a linear
regulator with good HF PSRR between it and the
amplifier, and filter before and after the linear
regulator.
Or, you insist that the customer provide the
Vg supply with such-and-such attributes, that
enables you to meet noise specs.
