shadow_khan
Junior Member level 2
Hi all,
I am a beginner in using HFSS.
Need your kindly advice and assist if you don't mind.
Currently I'm designing a printed antenna using HFSS, this figure show the antenna structure and geometry:
The problem is the simulation give a negative gain as the result.
I am sure there a mistake in my design (project file) and not in the antenna structure or dimension, because this antenna has already mass fabricated and being used world wide. I just simply use its structure and dimension to check while deepening my understanding in using HFSS.
Please find my HFSS simulation file, hopefully somebody could download and check it. And let me know, where did I get wrong.
Btw, what is the name of this antenna? I just name it printed folded dipole antenna. cmiiw.
Thank you in advance.
