Negative Capacitor Circuit
lisawoods
Does anyone have experience of designing a Negative Capacitor circuit ? I would like some help if possible
There is an active circuit with one opamp called NIC (negative impedance converter) which transforms a real load component (resistor or capacitor) into its negative equivalent. Therefore, search for NIC circuit (in each opamp application book or paper).
NIC are very interesting things and it has difficult explanation. You must go deeper to understand it. :D
Sorry, I cannot agree on this. It´s basic to calculate NIC properties - and also to understand the principle, provided one knows what a controlled source is.
whats the best reference source on this.. i want to match an antenna using a NIC circuit
The purpose of antenna matching is either maximum SNR (receiver) or efficiency (transmitter). It neither works with an active circuit as a NIC.
Fvm
i think you are wrong, it is an alternative to matching electrically small antenna. Which are very difficult to match because of the very high Q Factor. Using a passive network to match the antenna will introduce significant losses into the overall system. NIC can overcome this to some degree and improve the match to the antenna without the big losses associated with a traditional passive network.
If you can show a reasonable solution, I'll agree about being wrong. Is it a RX or TX antenna?
Are you referring to loading the antenna, not impedance matching for power transfer?
