needs help on CLOCK with FPGA
pantho
needs help on CLOCK
Hello everyone,
Good Day.
I want to download the following VHDL code to FPGA Xilinx Virtex-4.
process(clk)
begin
if (clk'event and clk = '1') then
if (cycle = '0') then
x <= a;
cycle <= '1';
else
x <= b;
cycle <= '0';
end if;
end if;
end process;
I have downloaded this to the FPGA. I have given input by DIP switch (An active low signal is generated when a given switch is ON) and output is in LED (turned “ON” by driving the LEDx signal to logic “0”). the result is as follows:
1. when a=11 and b=11 (by DIP switch), ALL output LED is OFF
2. when a=01 and b=01 , x(1) is MORE BRIGHT, x(0) is OFF
3. when a=11 and b=01 , x(1) is LESS BRIGHT, x(0) is OFF
Can I explain the result like this, because of the RAPID clocking, x changes rapidly. When it has the same value as previous, it is BRIGHT. and when it has different values, it is less bright.
I am using CLK_100 (System Clock – This clock input is connected to a 100MHz LVTTL oscillator) as clk. How can I control the clock speed?
regards and thanks in advance
pantho
