Need VHDL coding for backpropagation algorithm in neural networks
ragunathan
Newbie level 3
coimbatore
can any one help me to write a VHDL code for backpropagation algorithm in neural networks with block diagram
Any particular reason you decided to do it in hardware ?
no i'm not doing it in hardware.. doing simulation to identify t faults..
If you're using VHDL - you are doing it in hardware!
I suggest you implement the CORE algorithm in software (ie. use a CPU). Software is much more abstract - and when designing with complex algorithms this will prove beneficial. You can use hardware to accelerate the software and improve performance but I wouln't suggest implementing the CORE in software...
