need VHDL code for 16 bit BCD counter
hasitri
Junior Member level 1
16 bit counter vhdl
can any body help me........................
nand_gates
Advanced Member level 3
6 bit bcd code
Here is verilog code for 16 bit bcd up counter translate this to VHDL!
Hope this helps!
module bcd_count (
   // Outputs
   count,
   // Inputs
   clk, reset_n
   input clk, reset_n;
   output [15:0] count;
   reg [15:0] count;
   always @(posedge clk or negedge reset_n) begin
      if (!reset_n) begin
         count <= 0;
      end else begin
         if (count[3:0] == 9) begin
            count[3:0] <= 0;
            if (count[7:4] == 9) begin
               count[7:4] <= 0;
               if (count[11:8] == 9) begin
                  count[11:8] <= 0;
                  if (count[15:12] == 9) begin
                     count[15:12] <= 0;
                  end else begin
                     count[15:12] <= count[15:12] + 1;
                  end
               end else begin
                  count[11:8] <= count[11:8] + 1;
               end
            end else begin
               count[7:4] <= count[7:4] + 1;
            end
         end else begin
            count[3:0] <= count[3:0] + 1;
         end
      end
   end
endmodule // bcd_count
    hasitri
wiztronix
Full Member level 2
INDIA
vhdl 16 bit counter
where can i lay my grubby paws on a verilog to vhdl cross compiler? (if that;s what it is called..)
also can someone tell me if i can get a free c to vhdl crosscompiler/convertor??
regards,
wiztronix
buark
bcd to 16 bit
You can not convert c to vhdl, dont try and think about it
respect vhdl
hasitri
vhdl code for bcd counter
frns......
i converted the code into VHDL. but couldnt compile because of errors
the errors are
Error (10500): VHDL syntax error at BCD_16.vhd(14) near text "if"; expecting "end", or "(", or an identifier ("if" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at BCD_16.vhd(15) near text "elsif"; expecting "end", or "(", or an identifier ("elsif" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at BCD_16.vhd(15) near text "then"; expecting "<="
Error (10500): VHDL syntax error at BCD_16.vhd(16) near text "="; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at BCD_16.vhd(17) near text "if"; expecting "end", or "(", or an identifier ("if" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at BCD_16.vhd(17) near text "="; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at BCD_16.vhd(18) near text "if"; expecting "end", or "(", or an identifier ("if" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at BCD_16.vhd(18) near text "="; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at BCD_16.vhd(19) near text "if"; expecting "end", or "(", or an identifier ("if" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at BCD_16.vhd(19) near text "="; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at BCD_16.vhd(20) near text "else"; expecting "end", or "(", or an identifier ("else" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at BCD_16.vhd(21) near text "if"; expecting ";", or an identifier ("if" is a reserved keyword), or "architecture"
Error (10500): VHDL syntax error at BCD_16.vhd(23) near text "if"; expecting ";", or an identifier ("if" is a reserved keyword), or "architecture"
Error (10500): VHDL syntax error at BCD_16.vhd(25) near text "if"; expecting ";", or an identifier ("if" is a reserved keyword), or "architecture"
Error (10500): VHDL syntax error at BCD_16.vhd(27) near text "if"; expecting ";", or an identifier ("if" is a reserved keyword), or "architecture"
here's the code:
anybody help me in analyzing the errors.
library ieee;
use ieee.std_logic_1164.all;
entity bcd_16 is
port(
clk, reset : in std_logic;
count : out std_logic_vector (15 downto 0)
end bcd_16;
architecture counter of bcd_16 is
begin
if reset = '1' then count <= ( others => 0);
elsif ( clk'event and clk = '1') then
if count ( 3 downto 0) = "1001" then count(3 downto 0) <= "0000";
if count ( 7 downto 4) = "1001" then count(7 downto 4) <= "0000";
if count ( 11 downto 8 ) = "1001" then count(11 downto 8 ) <= "0000";
if count ( 15 downto 12) = "1001" then count(15 downto 12) <= "0000";
else count(15 downto 12) <= count(15 downto 12) + '1';
end if;
else count(11 downto 8 ) <= count(11 downto 8 ) + '1';
end if;
end if;
else count(3 downto 0 ) <= count(3 downto 0 ) + '1';
end if;
end if;
end counter;
nand_gates
bcd counter vhdl
Here it goes!
Checkout this!
library ieee;
use ieee.std_logic_unsigned.all;
entity bcd_16 is
  port(
    count      : buffer std_logic_vector (15 downto 0)
end bcd_16;
begin
bcd_counting: process (clk, reset)
begin  -- process bcd_counting
  if reset = '1' then                   -- asynchronous reset (active high)
    count <= ( others => '0');
  elsif clk'event and clk = '1' then    -- rising clock edge
          else
          end if;
        else
        end if;
      else
      end if;
    else
    end if;
  end if;
end process bcd_counting;
end counter;
Reactions: Tero
    hasitri
    Tero
hasitri
16 bit program counter .hdl
thanks again nand_gates
can u tell me why the code gives error widout process statement?
nand_gates
vhd 16bit counter
if then else end if statement is sequential statement only valid in process
construct. Thats why you were getting the errors!
hasitri
16 bit counter implementation in fpga
yeah thanks i got that point.
wiztronix
Full Member level 2
INDIA
vhdl syntax error near text )
hey buark,
i think you would do good to check this out regarding C and VHDL
https://www.impulsec.com/
also no offence mean bro, but i dont quite agree in principle to the statement
"respect VHDL"
i mean whats there to respect?? its just another tool like C or Assembly language for that matter.. whats to be respected is the concept of programming or the finesse of implementation.. dont ya think so?
regards,
wiztronix
emilliano
Newbie level 1
Malaysia
Thank you very much Nand Gates
You have saved my project research, because I have tried create BCD counter 64 Bit, it can run successfully (using combination binary counter and comparator bcd) but It can't reset successfully.
After I run with your program It can run successfully.
Thank you very much.
I will give you my modification program BCD Counter 16 Bit can reset and run with Xilinx ISE XST and Xilinx ISE Simulator successfully.
Best Regards,
Emilliano
PhD with RA
Malaysia
-- Company:
-- Engineer:
-- Create Date: 10:46:02 12/24/2009
-- Design Name:
-- Module Name: emil_36c - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity emil_36c is
port(
bcd1 : out std_logic_vector (3 downto 0);
bcd2 : out std_logic_vector (3 downto 0);
bcd3 : out std_logic_vector (3 downto 0);
bcd4 : out std_logic_vector (3 downto 0));
end emil_36c;
architecture Behavioral of emil_36c is
signal bcd1_int : std_logic_vector (3 downto 0) := "0000";
signal bcd2_int : std_logic_vector (3 downto 0) := "0000";
signal bcd3_int : std_logic_vector (3 downto 0) := "0000";
signal bcd4_int : std_logic_vector (3 downto 0) := "0000";
begin
bcd1_int <= ( others => '0');
bcd2_int <= ( others => '0');
bcd3_int <= ( others => '0');
bcd4_int <= ( others => '0');
if bcd1_int = "1001" then
bcd1_int <= "0000";
if bcd2_int = "1001" then
bcd2_int <= "0000";
if bcd3_int = "1001" then
bcd3_int <= "0000";
if bcd4_int = "1001" then
bcd4_int <= "0000";
else
bcd4_int <= bcd4_int + '1';
end if;
else
bcd3_int <= bcd3_int + '1';
end if;
else
bcd2_int <= bcd2_int + '1';
end if;
else
bcd1_int <= bcd1_int + '1';
end if;
end if;
end process;
bcd1 <= bcd1_int;
bcd2 <= bcd2_int;
bcd3 <= bcd3_int;
bcd4 <= bcd4_int;
end Behavioral;
Vinch Singh
Newbie level 2
Singapore
Hey, Could someone please post me how to write 5bit Up/Down Counter with reset and preset in VHDL?
I was blur because of the usage of preset.. Thanks
