need urgent solution today, requesting all the seniors to please provide solution
ranveer247
Newbie level 1
Newbie level 1
i want to interface lcd display and display WELCOME INSTEAD OF MECHATRONICS.
But after checking syntex its showng syntex error!
Compiling vhdl file c:/xilinx/bin/lcdint/lcdinterface.vhd in Library work.
ERROR:HDLParsers:164 - c:/xilinx/bin/lcdint/lcdinterface.vhd Line 24. parse error, unexpected SIGNAL
ERROR: XST failed
Process "Check Syntax" did not complete.
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
--  Uncomment the following lines to use the declarations that are
--  provided for instantiating Xilinx primitive components.
--library UNISIM;
--use UNISIM.VComponents.all;
entity test_lcd_mod is
port(   CLK_4M          : in STD_LOGIC;  -- 4 Mhz
        RESET               : in STD_LOGIC;
        LCD_D           : out STD_LOGIC_VECTOR (7 downto 0);
        LCD_RW          : out STD_LOGIC;
        LCD_RS          : out STD_LOGIC;
        LCD_E           : out STD_LOGIC ;
          posedge_clk       : out std_logic
end test_lcd_mod;
architecture Behavioral of test_lcd_mod is
 -- signal
signal data_s,data_s1 : std_logic_vector(9 downto 0);
signal edge1 : std_logic_vector(1 downto 0);
signal refresh,refresh_d,refresh_s : std_logic;
signal en1,en2 : std_logic;
signal lcd_data : std_logic_vector(7 downto 0);
signal lcd_clk : std_logic;--152 Hz
signal lcd_posedge_s : std_logic;-- pose edge of 152 Hz
signal Div : std_logic_vector(10 downto 0);
type state is (wait_state1,func_set0,func_set0_t,func_set0_t1,func_set0_t2,func_set1,func_set1_t,func_set2,func_set2_t,func_set3,func_set3_t,
                    disp_ctrl,disp_ctrl_t,clear_disp,clear_disp_t, mode_set,mode_set_t,cur_set,cur_set_t,ddram_add,ddram_add_t );
signal ps_1, ns_1 : state;
type state1 is (wait_state2,idle1,idle,M,E,C,H,A,T,R,O,N,I,C1,S);
signal prst, nxt : state1;
begin
-- Note this design works with a clock of 4M for any other clock plaese modify suitably
-----------LCD CLOCK GENERATION(152 HZ)--------------------------------
process(RESET, CLK_4M,Div)
begin
 if( RESET = '1' )then
    Div <= (others=>'0');
  elsif(CLK_4M'event and CLK_4M = '1')then
    Div <= Div + 1;
 end if;
end process;
lcd_clk <= Div(10);
en2 <= Div(10);
-- ** Generate a pulse of 4M width on postive edge of LCD_Clock. starts here
process(RESET,CLK_4M,lcd_clk)
begin
    if RESET = '1' then
        edge1 <= "00";
    elsif (CLK_4M'event and CLK_4M = '0') then
        edge1(0)<= lcd_clk;
        edge1(1)<= edge1(0);
    end if;
end process;
lcd_posedge_s <= ((not edge1(1)) and edge1(0));
posedge_clk <= lcd_posedge_s;
-- ** Generate a pulse of 4M width on postive edge of LCD_Clock. ends here
--lcd_clk_led <= lcd_posedge_s;
--********This FSM  Intializes the LCD **************************
process(RESET,CLK_4M,ns_1,lcd_posedge_s)
begin
     if(RESET = '1') then
         ps_1 <= func_set0;
    elsif(CLK_4M'event and CLK_4M = '1') then
        if(lcd_posedge_s = '1') then
            ps_1 <= ns_1;
        end if;
    end if;
end process;
--next state decoder
process(ps_1)
begin
      case ps_1 is
        when func_set0 =>    ns_1 <= func_set0_t;
        when func_set0_t => ns_1 <= func_set0_t1;
        when func_set0_t1 => ns_1 <= func_set0_t2;
        when func_set0_t2 =>    ns_1 <= func_set1;
        when func_set1 =>    ns_1 <= func_set1_t;
        when func_set1_t => ns_1 <= func_set2;
      when func_set2 =>    ns_1 <= func_set2_t;
        when func_set2_t => ns_1 <= func_set3;
        when func_set3 =>    ns_1 <= func_set3_t;
        when func_set3_t => ns_1 <= disp_ctrl;
        when disp_ctrl =>    ns_1 <= disp_ctrl_t;
        when disp_ctrl_t => ns_1 <= cur_set;
       when cur_set  =>     ns_1 <= cur_set_t;
        when cur_set_t =>   ns_1 <= mode_set;
        when mode_set =>     ns_1 <= mode_set_t;
        when mode_set_t =>  ns_1 <= ddram_add;
      when ddram_add =>    ns_1 <= ddram_add_t;
        when ddram_add_t => ns_1 <= clear_disp;
        when clear_disp =>   ns_1 <= clear_disp_t;
        when clear_disp_t =>    ns_1 <= wait_state1;
-- LCD intialization FSM locks itself in wait_state1 after intialization is over
        when wait_state1 => ns_1 <= wait_state1;
        when others =>       ns_1 <= func_set0;
   end case;
end process;
--process output decoder
process(ps_1)
begin
      case ps_1 is
            when func_set0 =>
                        refresh <= '0';
                        en1 <= '1';
                        data_s <=  "0000110000";
            when func_set0_t =>
                        refresh <= '0';
                        en1 <= '0';
                        refresh <= '0';
                        en1 <= '1';
                        refresh <= '0';
                        en1 <= '0';
                when func_set1 =>
                        refresh <= '0';
                        en1 <= '1';
            when func_set1_t =>
                       refresh <= '0';
                       en1 <= '0';
            when func_set2 =>
                       refresh <= '0';
                       en1 <= '1';
            when func_set2_t =>
                       refresh <= '0';
                       en1 <= '0';
            when func_set3 =>
                       refresh <= '0';
                       en1 <= '1';
                       data_s <= "0000111000";
            when func_set3_t =>
                       refresh <= '0';
                       en1 <= '0';
            when disp_ctrl =>
                       refresh <= '0';
                       en1 <= '1';
                        data_s <= "0000001110";
            when disp_ctrl_t =>
                      refresh <= '0';
                      en1 <= '0';
            when cur_set  =>
                      refresh <= '0';
                      en1 <= '1';
                      data_s <= "0000011100";
            when cur_set_t  =>
                      refresh <= '0';
                      en1 <= '0';
            when mode_set =>
                      refresh <= '0';
                      en1 <= '1';
                      data_s <= "0000000110" ;
            when mode_set_t =>
                    refresh <= '0';
                    en1 <= '0';
                when ddram_add =>
                    refresh <= '0';
                    en1 <= '1';
                    data_s <= "0010000000";
                when ddram_add_t =>
                    refresh <= '0';
                    en1 <= '0';
            when clear_disp =>
                    refresh <= '0';
                    en1 <= '1';
                    data_s <= "0000000001";
                    refresh <= '0';
                    en1 <= '0';
            when wait_state1 =>
                      refresh <= '1';
                  en1 <= '0';
                   data_s <= "0000000000";
            when others =>
                  refresh <= '0';
                    en1 <= '0';
     end case;
end process;
--********LCD Intialization ENDS HERE **************************
--- *******  This FSM writes Data to LCD.
--- This FSM starts after the LCD Initialization is over
process(RESET,CLK_4M,refresh,lcd_posedge_s)
begin
         refresh_d <= '0';
            refresh_d <= refresh;
        end if;
    end if;
end process;
refresh_s <= '1' when (refresh = '1' and refresh_d = '0') else
             '0';
--state2
process(RESET,CLK_4M,lcd_posedge_s)
begin
           prst <= wait_state2;
           prst <= nxt;
        end if;
    end if;
end process;
process(prst,refresh_s)
begin
     case prst is
-- loop in wait state2 till the LCD is being Intialized
        when wait_state2 =>
        if(refresh_s = '1') then    nxt <= idle1;
                                  else nxt <= wait_state2; --
          end if;
        when idle1 =>  nxt <=idle;
        when idle =>  nxt <= M;
        when M =>  nxt <= E;
        when E =>  nxt <= C;
        when C =>  nxt <= H;
        when H =>  nxt <= A;
        when A =>  nxt <= T;
        when T =>  nxt <= R;
        when R =>  nxt <= O;
        when O =>  nxt <= N;
        when N =>  nxt <= I;
        when I =>  nxt <= C1;
        when C1 => nxt <= S;
        when others => nxt <= wait_state2;
     end case;
end process;
--output decoder
process(prst)
begin
case prst is
          when wait_state2 =>
                     data_s1 <= "0000000000";
            when M =>  data_s1 <=  "1001001101";
            when E =>  data_s1 <=  "1001000101";
            when C =>  data_s1 <=  "1001000011";
          when H =>  data_s1 <=  "1001001000";
           when A =>  data_s1 <=  "1001000001";
           when T =>  data_s1 <=  "1001010100";
           when R =>  data_s1 <=  "1001010010";
           when O =>  data_s1 <=  "1001001111";
            when N =>  data_s1 <=  "1001001110";
            when I =>  data_s1 <=  "1001001001";
            when C1 =>  data_s1 <=  "1001000011";
            when S =>  data_s1 <=  "1001010011";
           when others =>
     end case;
end process;
LCD_D   <= data_s(7 downto 0) or data_s1(7 downto 0);
LCD_RS     <= data_s(9) or data_s1(9);
LCD_RW     <= data_s(8) or data_s1(8);
LCD_E     <= en1 or en2;
end Behavioral;
1) That's pretty presumptuous of you to demand an "urgent solution today" and "all seniors to provide solution". Why should we, because you say we should? Maybe you should try a different approach.
2)Line numbers would help.
Not out of any interest to help the OP, but only because I couldn't see anything wrong with the file. I tried synthesizing the file and it only had warnings about some signals reducing to a logic 0 after synthesis.
