1.All doors are normally closed and locked through Magnetic Lock.
2. Opening any door causes the second door to lock until the opened door returns to the closed position.
3. A key switch provides system on-off control.
4.An optional manual switch on the top of the door to operate the switch manually bypassing the automatic mechanism.
Read your query. Can you tell me where are you located and your contact info where i can contact you. I think i might be able to help you with your query.
