EDA_hg81
Advanced Member level 2
process ( iARM7_CLK )
begin
if ( rising_edge( iARM7_CLK ) ) then
spiclkcon <= spiclkcon + 1;
if ( spiclkcon = spiclk_gen ) then
spiclkcon <= x"00";
spiclk <= not spiclk;
end if;
if ( iSD_INISTATUS(0) = '0' ) then ******* when initialization is ok
if ( spiclkcon = spiclk_cap and spiclk = '0' ) then
case readstatus is
when x"00" =>
if ( sdread = '1' ) then
datain1 <= x"FFFFFFFF";
readstatus <= x"01";
end if;
when x"01" =>
outdata <= datain1; **** data is captured when situation "spiclkcon = spiclk_cap and spiclk = '0'" is met
readstatus <= x"00";
when others => null;
end case;
else
outdata <= x"FFFF0000"; **** x"FFFF0000" is sent out when "spiclkcon = spiclk_cap and spiclk = '0'" is not met
end if;
elsif ( iSD_INISTATUS(0) = '1' ) then **** when initialization is not finished readstatus back to x"00"
end if;
end if;
end process;
This process is for reading SD card ID (such as x”260032”).
The problem is:
At the beginning, the output ID data can be read properly but when the SD card is taken out from slot, the output ID data still is x”260032” instead of x”FFFF0000”.
I decided the reason for above problem is that ID data is captured inside spiclk clock domain ( 2.5MHZ) which is generated by a clock divider and the “outdata” register can not be updated properly since “outdata” register is synchronized with iARM7_CLK (50MHZ).
I tried use:
else
to fix above problem.
But this time ID outdata is always x”FFFF0000”.
I have used scope to verify the input data, the looks fine.
How I can fix this problem?
Thanks.
