Re: need tutorial of how to simulate yagi antenna using hfss
yagi is a simple antenna.u start with a dipole for your omni directional patterns.followed by
The director/s is the shortest of the parasitic elements and this end of the Yagi is aimed at the receiving station. It is resonant slightly higher in frequency than the driven element, and its length will be about 5% shorter, progressively than the driven element. The director/s length/s can vary, depending upon the director spacing, the number of directors used in the antenna, the desired pattern, pattern bandwidth and element diameter. The number of directors that can be used are determined by the physical size (length) of the supporting boom needed by your design.
The reflector is the element that is placed at the rear of the driven element (The dipole). It's resonant frequency is lower, and its length is approximately 5% longer than the driven element. It's length will vary depending on the spacing and the element diameter. The spacing of the reflector will be between .1 wavelength and .25 wavelength. It's spacing will depend upon the gain, bandwidth, F/B ratio, and sidelobe pattern requirements of the final antenna design.
hope this will help.if not i can do a quick simulation for you.
Sajid Mohammed.
