Need to write verilog code for following case
kth_hkt
Newbie
Newbie level 3
I have a memory of depth 4 and 8 bytes wide.
I need to read first two bytes of first address of the memory and calculate its sum and find the average and replace the first two bytes of first address by that average.
Then I need to read the contents of subsequent two bytes of the first address itself and again do sum and find average and then replace third and fourth bytes by that average. This process should continue for all the addresses .
Ex: If the memory is something like this
31243553
22113133
42020464
28268097
Then, first two bits of first address must be replaced by (3+1)/2 = 2
and then next two bits of address must be replaced by (2+4)/2=3,
and so on, for all bytes of all the addresses
Finally the memory should look like,
22334444
22112233
33112255
55444488
I need to write verilog code for this design and the code should be parameterized such that it can be extended to any width and any depth.
I´m totally confused.
Nothing matches.
I have a memory of depth 4 and 8 bits wide.
so 4x 8 bits = 4 x 1 byte.
one bit can have the value 0 or 1. so why does you table show values > 1?
did you confuse bits and bytes?
Then, first two bits of first address must be replaced by (3+1)/2 = 4
Formula is wrong
and then next two bits of address must be replaced by (2+4)/=3,
Formula is wrong
What does your table show? What are the columns? what are the rows? --> give description, work with colors.
Klaus
Nothing matches.
Formula is wrong
Formula is wrong
Klaus
Yes, I got confused with bits and bytes and made appropriate edits in the question.
so the math is clear so far (I hope).
Please provide clear descriptions, like
* one table row shows the contents (8 bytes, starting from left side) of one address (0...3)
(often bit order / byte order is descending, thus the other way round than in your example)
so the system should be (like may systems)
INPUT --> CALCULATE --> OUTPUT
you need to clarify:
* How do you access the input and the output?
* What if the sum of two numbers is an odd value?
* What is your system clock freuquency?
* What is the memory timing?
* What is the calculation timing?
Klaus
Klaus
In first clock pulse all the 8 bytes are read from the first address and added in pairs and and then average is calculated and replaced. All these things occur in one clock pulse i.e. [(3+1)/2], [(2+4)/2],[(3+5)/2] and [(5+3)/2] this calculation and replacement. Therefore, after 4 clock pulses in this case the total memory gets updated with the corresponding average values. There are no other constraints I can think of now.
If you are supposed to read and write in the same clock cycle then it's probably not something you want to do in an SRAM as that requires a dual port SRAM with a read before write behavior that works.
As this is homework you won't get someone to write this for you. You should start by breaking this down into smaller pieces.
  1. what are your input and output ports on the module? ... read about how to write the module ports and how to use parameters
  2. how are you going to define your "memory"?... read about Verilog arrays
  3. how do you write a register?... look for examples of basic logic written in Verilog
  4. how do you index (count) through the memory "addresses"?... read about counters
  5. how to you use the address to select the correct memory address (assuming you are using registers for the memory)? ... read about multiplexers and de-multiplexers.
  6. how are you going to determine your code works?...read about testbenching.
That should get you started on what you need to know to do your homework.
