I am designing a PCB board which consists of controller, Motor driver and LCD panel. Here the LCD panel input is feeding from the PCB board using FFC connector. Now i am thinking to modify the way of connection. Instead of FFC connector, I would like to integrate my LCD panel with PCB board using BURG STRIP through hole connector. Shall i proceed that? If i do so, any other problem may rise or not. Please help me..
The only problem I could foresee would be if there is excessive shock the Berg strip/pcb connection could fracture, whereas the flat cable gives more tolerance to shock and vibration. But the rigid header approach is used ALL THE TIME, so unless you've got some special circumstances, I don't see a problem.
