Need to measure battery internal resistance
Ultor
Newbie level 3
Does anyone know how I can measure a battery's internal resistance while it's still connected to a circuit? I have a need to measure a lead-acid cell's internal resistance.
Anyone with some ideas?
Robert
As far as I know, this is done on a per-cell basis (if individual cells have external connections) or for the entire battery.
In any case, a certain load is connected across the cell or battery and the voltage is measured. By measuring both the no-load voltage and the loaded voltage you can easily calculate the internal resistance of the battery
Rbatt=ΔV/I
where ΔV is the difference between the open-circuit voltage and the voltage under load and I is the actual current when the load is connected.
If the battery is in the circuit, you can measure the voltage difference for two different currents, for instance, but you need a way to change the load current and a way to measure accurately the change. Measuring the voltage change is not a problem, a voltmeter will do.
    Ultor
Rbatt=ΔV/I
VVV, did you check these ? How much must the current be?
:p
:p
The more the better.
Let's be reasonable, we are not talking about 1000A :D
yes not 1000A.
but for a 12V/12Ah a current around 1A is good?
