Need to emulate a potentiometer electronically
blapcb
Full Member level 3
Planet earth (most of the time)
potentiometer emulation
I have a mechanical device that basically is tied to a potentiometer that gives out a reading according to the position of the device (say 0 to 200 ohms). This resistance drives an electronic (analog) meter. I would like to replace the mechanical device with an electronic one (for better precision) but still use the existing analog meter for display. So, I need to emulate the resistance. Any ideas?
Added after 7 minutes:
I would like to add that yes there are some very cool digital potentiometers ("digipots") such as those from Microgip or Analog, but they are in the Kohm range and I need one from 0 to 200 or so....
electronically simulate potentiometer
Hello!
I don't get the exact picture of what you want to do, but just in case,
you might be interested by these devices.
Edit : Oops, I gave you this response apparently before you added
the last sentence...
Dora.
I don't think, that you need a simulated potentiometer or resistor to drive the analog meter, because the primary input signal is most likely a voltage or current. I guess, it's a bigger problem to achieve similar resolution and accuracy with an electronic position sensor, unless you go for a high end digital position encoders.
