Need to buy off-the-shelf power supply of a certain spec
T
treez
Newbie level 1
Hello
We need an offtheshelf offline PSU.
The spec is as follows…
200 to 400w output (anywhere in that range)
VAC input = 100-265VAC
Vout = either 12V or 15V or 24V
No Fan
Metal casing so it can be screwed to a metal enclosure for thermal management.
Fully enclosed , but only to IP51 rating.
Dimensions is open
It is not possible to sort power supplies on this basis, either direct from manufacturers sites such as meanwell, or from digikey.
Do you know how I can find such power supplies?
We found the meanwell HEP-240 after much searching, but that is only one...we need to cost-compare many
https://www.meanwell.com/webapp/product/search.aspx?prod=HEP-240
