[SOLVED] Need suggestion to desing a Development board for PIC 16F series
Mithun_K_Das
Advanced Member level 3
Dhaka, Bangladesh, Bangladesh
I'm going to design a development board for PIC 16F series. What I'm planning to make all possible and required option to work with the MCU easily. Mostly I want to make it to work with Power Electronics.
So I need your suggestion.
I liked these: Need your suggestion:
As you can see from your own pictures they are all virtually the same.
Would suggest you make a core board containing the standard parts and ensure you have plenty of connectors to easily add on extra devices / i/o etc.
The Eblock method allows you to produce a very flexible system. http://www.matrixmultimedia.com/eblocks.php
