scream_er
Member level 5
Can someone tell me a rail to rail op-amp that can be used with single supply 5V to 9V. Something easy and similar to LM358, also inexpensive.
I want a rail to rail op-amp that use single supply so that I can bais it somewhere at 2.5V and still get 0 to 5V using a battery. I have found a couple of op-amps, which are: TLC272, LT1466, LM324N, TLV2771, LM6144. What could be the best choice, or is there anything else that you suggest?
Thanks
Thanks
