fist of all you need to understand the "AT" commands. Do it by your self . If any problem faced in the way i'll help you. In this forum you will get many examples. Search the forum
if you mean is using pic send AT command to GSM modem for sms application. i can help you.
this is source code i use Pic 18f252 to send AT command to sim508 for sending sms. and i sucsessed.
send sequence of AT command:
-AT+CMGF=1
-AT+CSCS="GSM"
-AT+CMGD=1
-AT+CMGS= "destination phone number"
- if GSM modem respone ">" type data
- end sending: send 0x0A to sim 508
- if you want to stop send sms: send 0x1B
what language are you going to use?it is not possible to write the AT commands directly as it is if you are going to use a programming language to program it with your pic
I am using microbasic and my problem now is to put info into a cicular buffer before i push the information to the uart using the FIFO(first in first out) principle. Can someone please help me with some code that puts info as it come into a circular buffer whilst waiting for the UART to finish sending current information being send
