McMurry
Member level 3
I had developed a 4-channel temperature monitoring system (using 1-wire protocol) that displays temp reading from up to 4 sensor on the computer GUI. In the computer, user can set his desired min and max safe temperature range for EACH temperature sensor. alarm and corresponding LED indicator will turn on when this range is exceeded.
From some journals I read, they have their system added with extensive control algorithm.
I have not much time to add or change additional control algorithm to the system... but can anyone think of some good applications of the system I currently have?
Thanks in advance.
Thanks in advance.
