Need some help with _BV() macro
borge
Junior Member level 1
Norway
Hi
Have been reading up on Pogramming, and starting to understand some basics.
I got a problem when i wanted to add more ports to this easy tutorial.
When i added the _BV(PD5), this was the only led blinking, not both. how do i configure this.
Do i need to define the pins separately ?
I have searched the net, but not any clear answers.
I used Programmers notepad.
#include <avr/interrupt.h>
#define F_CPU 100000UL
#include <util\delay.h>
int main()
DDRD = _BV(PD4);           // this is the original
DDRD = _BV(PD5);           // i added this
while(1) {
PORTD = _BV(PD4);
_delay_ms(1000);
PORTD  &= ~_BV(PD4);
_delay_ms(1000);
PORTD = _BV(PD5);                  // The PD5 i added
_delay_ms(1000);
PORTD &= _BV(PD5);
_delay_ms(1000);
   return (0);
_BV(x) is the equivalent of (1<<x)
When you use
it is the equivalent of
DDRD = 0b00010000;
DDRD = 0b00100000;
So you assign a value and then another value so only the last value stands
In order to preserve the value and set another bit you have to use the OR operator
DDRD = _BV(PD4);
DDRD |= _BV(PD5);      // the equivalent of DDRD =  DDRD | _BV(PD5);
Even better is to do this
DDRD = _BV(PD5) | _BV(PD4);
You should apply OR in a similar manner when you set the port
PORTD = _BV(PD5);                  // this assigns 0 to all bits except from bit 5
Use this instead
PORTD |= _BV(PD5);                  // keep the current value and in addition set bit5
Reactions: borge
    borge
Thanks alexan_e.
Will try this evening.
When i use this, and configuring two ports or more, do i continue with the
PORTD [COLOR="#FF0000"]|[/COLOR]= _BV macro  //for each port
And keep the first without th OR Operator
PORTD = _BV(PD4);
Reactions: borge
    borge
Thanks alexan_e
your help did the trick. and i read from the link you gave me.
i used both the _BV macro, and 0b1000000; way to test, varied the delay and played around with it.
:smile:
